About converting axf file
1,275 次查看
Ayhan14
I want to convert from axf to mhx extension. How can I do this conversion in MCUXpresso IDE?
Oguzhan Ayhan
1,249 次查看
diego_charles
Hi @Ayhan14
I am unfamiliar with mhx extension, which part and end  tool are you going to  use to process  this extension?
I do not know the ARM toolchain supports this extension, if it does you could try a command, and those commands can be invoked by the MCUXpresso, as after build commands. See this entry from Erich Styger's blog  MCUXpresso IDE: S-Record, Intel Hex and Binary Files
Diego
