Run Thread border router scenario on FRDM-KW41Z
3,428 次查看
sterenn
I am going through the proposed demos for thread in the Kinetis Thread Stack Demo Applications User Guide, and I am in need of a thread border router. However, I see no such example in my downloaded SDK. The Thread examples I have are the following : end_device, host_controlled_device, low_power_end_device, router_eligible_device (and same for OTAP).
I also read something about host-controlled interface that can fullfill the role of border router, but I don't know how to do it.
Thank you,
2,941 次查看
sterenn
Hello again,
I downloaded the USB-KW41Z software and flashed it to the FRDM-KW41Z board. I had to struggle somehow with the FRDM-KW41Z bootloader mode (this document saved me), but finally succeeded in updating the OpenSDA port and loading the border_router scenario on the board.
During this process, several installations of drivers were performed (J-Link, mbedWinSerial, lpc drivers). However, I still cannot see the desired "NXP RNDIS router" in my device manager as expected when following the Kinetis Thread Stack Demo Applications User's Guide, Chap.11, Border router scenarios.
So, I still got the same question : is it supposed to work on FRDM-KW41Z or should I stop now ?
Thank you,
Sterenn
UPDATE : Should stop now and use USB-KW41Z software for USB-KW41Z only.
2,941 次查看
stephanie_m
The border router software it's available for the USB-KW41, you can download this software in the MCUXpresso SDK Builder.
Estephania
2,942 次查看
sterenn
Hello again,
Thank you,
Sterenn
2,941 次查看
sterenn
Hello, thank you for your answer.
My problem is, that I don't have the USB-KW41 device, so I'm affraid it's border software won't work well on my FRDM-KW41Z devices. Is it possible for me to run a special FRDM-KW41Z scenario that would allow me to have it behave as border router ?
