Processing:$01008000
3,971件の閲覧回数
185206778
选好.s19程序文件后按Start,显示屏显示“Processing:$01008000”后就不动了, 是什么原因?怎么处理?
3 返答(返信)
3,828件の閲覧回数
Carlos_Mendoza
Hi Guo,
Could you give us more information about the MCU and software being used?
Hope it helps!
Carlos Mendoza
Technical Support Engineer
3,827件の閲覧回数
185206778
Hi Carlos,
The used MCU is SPC5746RK1MMT5,where I use cyclone universal V9.80 as the automated programmer tool. After pressing the "Start" button,it displays processing:$01008000 few seconds later,and then nothing changed ablout 10 mins later.
How can fix this problem,Carlos?
Thanks.
3,827件の閲覧回数
martin_kovar
in this case I recommend you to contact PEMicro support directly, because Cyclone universal is PEMicro product, so they can provide most accurate answer.
Martin
