LPC1769 PWM with MCUXpresso
2,501 次查看
jkeyman
I used LPCxpresso in the past for different projects. Now i wanted to use the new MCUxpresso and make some PWM outputs. But i am stuck. I can not find the names that MCUxpresso needs to find the pwm register. LPC_PWM1 is not recognised somehow.
Can maybe someone help me out ?
1,725 次查看
Carlos_Mendoza
Hi Mike,
The LPCOpen package does not include the PWM configuration files, you could use the configuration files from this post as reference for your application:
LPCOpen Pwm Driver
Or use the PWM driver that comes with the LPC175x_6x CMSIS-Compliant Standard Peripheral Firmware Driver Library:
LPC175x_6x CMSIS-Compliant Standard Peripheral Firmware Driver Library (Keil, IAR, GNU) | www.LPCwar...
Hope it helps!
Carlos Mendoza
Technical Support Engineer
