rw612 config
rw612 config
gtecaskari
The configuration tool is too annoying. I am using the RW612. In addition, the SDK is getting worse in newer versions. The configuration tool should generate the correct files in the root directory; although the .mex file exists, it is sometimes generated in a different folder. Overall, all of your tools and SDKs are horrible.
RomanVR
Hello @gtecaskari, hope you are doing well.
I'm sorry to read that you have encountered with some issues. To better analyze your issue could you please share your environment setup? Including your IDE (MCUXpresso IDE or MCUXpresso for VS Code), SDK version, RTOS, and the specific example that you are testing.
Best Regards!
gtecaskari
Hi. thanks for your answer. I have tried all version, 25.6 -25.9 - 25.12
25.12 is getting worse .
you can just compare it to stm32cubemx and can understand how awful is it.
RomanVR
Hi @gtecaskari.
Feel free to correct me if I'm wrong, but if you are using MCUXpresso for VS Code with Config Tools support, could you please confirm that you have followed the recommended workflow stated at the following page: Working with MCUXpresso Config Tools?
Additionally, it would be very helpful if you share with me the steps that you are following in order to reproduce your issue.
Best Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2305379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Erw612%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20configuration%20tool%20is%20too%20annoying.%20I%20am%20using%20the%20RW612.%20In%20addition%2C%20the%20SDK%20is%20getting%20worse%20in%20newer%20versions.%20The%20configuration%20tool%20should%20generate%20the%20correct%20files%20in%20the%20root%20directory%3B%20although%20the%20.mex%20file%20exists%2C%20it%20is%20sometimes%20generated%20in%20a%20different%20folder.%20Overall%2C%20all%20of%20your%20tools%20and%20SDKs%20are%20horrible.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244149%22%20target%3D%22_blank%22%3E%40gtecaskari%3C%2FA%3E%2C%26nbsp%3Bhope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3EI'm%20sorry%20to%20read%20that%20you%20have%20encountered%20with%20some%20issues.%20To%20better%20analyze%20your%20issue%20could%20you%20please%20share%20your%20environment%20setup%3F%20Including%20your%20IDE%20(MCUXpresso%20IDE%20or%20MCUXpresso%20for%20VS%20Code)%2C%20SDK%20version%2C%20RTOS%2C%20and%20the%20specific%20example%20that%20you%20are%20testing.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%20thanks%20for%20your%20answer.%20I%20have%20tried%20all%20version%2C%2025.6%20-25.9%20-%2025.12%3C%2FP%3E%3CP%3E25.12%20is%20getting%20worse%20.%3C%2FP%3E%3CP%3Eyou%20can%20just%20compare%20it%20to%20stm32cubemx%20and%20can%20understand%20how%20awful%20is%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rw612%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244149%22%20target%3D%22_blank%22%3E%40gtecaskari%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EFeel%20free%20to%20correct%20me%20if%20I'm%20wrong%2C%20but%20if%20you%20are%20using%20MCUXpresso%20for%20VS%20Code%20with%20Config%20Tools%20support%2C%20could%20you%20please%20confirm%20that%20you%20have%20followed%20the%20recommended%20workflow%20stated%20at%20the%20following%20page%3A%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcux-vscode%2Flatest%2Fhtml%2FWorking-with-MCUXpresso-Config-Tools.html%23working-with-mcuxpresso-config-tools%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EWorking%20with%20MCUXpresso%20Config%20Tools%3C%2FA%3E%3F%3C%2FP%3E%0A%3CP%3EAdditionally%2C%20it%20would%20be%20very%20helpful%20if%20you%20share%20with%20me%20the%20steps%20that%20you%20are%20following%20in%20order%20to%20reproduce%20your%20issue.%3C%2FP%3E%3C%2FLINGO-BODY%3E
