customize name BOARD_InitBootClocks() and BOARD_InitBootPins()
3,987件の閲覧回数
grzegorzkonopko
Is it possible to customize function name: BOARD_InitBootPins()?
I would like to have few hardware configuration in single projects and more than one name of such method will cause linker error.
4 返答(返信)
3,864件の閲覧回数
marek-trmac
Hi Grzegorz,
BOARD_InitBootPins() contains all configurations that should be executed after reset. You can add additional configuration called "Functional groups" using the toolbar and you can select for each, whether it will be invoked after reset or not.
For each functuional group, one C function is generated and its name is configurable.
BOARD_InitBootPins() name cannot be changed, the function is called from main.
Marek
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
3,864件の閲覧回数
grzegorzkonopko
I know how it works.
Is this forum a good place to ask for change request?
3,864件の閲覧回数
danielchen
You can create a support ticket or post on this forum for your request.
Support | NXP
3,864件の閲覧回数
marek-trmac
any improvement proposals are appreciated.
Marek
Marek
