Warning "Incorrect assignment on 'Identifier' item."
jonasa
I use
MCUXpresso Config Tools 25.12.
I get this issue on some pins:
Issue: Incorrect assignment on 'Identifier' item.
Level: Warning
Type: Tool problem
Tool: Pins
Origin: Pins:BOARD_InitPins
Resource: #1-LPUART_1.TX
Information: WARNINGS:
– The identifier should be specified to generate direction #defines properly in the header file.
But the Identifier is specified with OUT_UART1_RS485_2_D
Why do I get this warning?
Hello @jonasa
Please check whether the generated code is correct, and verify that the macros for the pin have been generated. If not, please check whether there is already another identifier assigned to this pin.
Thank you.
Alice
