Using PMIC MPF5020 with RT1175
2,263 次查看
mastupristi
Senior Contributor II
I saw that the config tools generates code that interacts with DCDC, but I want to bypass DCDC because I use an external PMIC.
How can I "tell" config tools not to use external DCDC because I have an external PMIC?
best regards
标记 (3)
2,241 次查看
Petr_H
It seems that this message is duplicated, see the solution here.
Petr Hradsky
Config Tools Team
2,242 次查看
Petr_H
Petr Hradsky
Config Tools Team
