MCUXpresso Software Development Kit
2,997 次查看
saeidsaeidi
I am trying to download "MCUXpresso Software Development Kit", however after many times trying, it seems that there is a Problem with the download link?
Thanks and regards!
Saeid
4 回复数
2,624 次查看
marek-trmac
Hi Saeid,
this community is related to MCUXpresso Config Tools.
Here is the link to SDK community: https://community.nxp.com/community/mcuxpresso/kinetis-software-development-kit
To download SDK v2.x use http://mcuxpresso.nxp.com/
Marek
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
2,624 次查看
saeidsaeidi
Hi Carlos,
thank you very much for the Information. In fact I would like to download the MCUXpresso Software Development Kit (SDK) which is described here:
http://www.nxp.com/products/developer-resources/run-time-software/mcuxpresso-software-and-tools/mcux...
I used the download link:
However there is no download file available.
It should be an aternative to IAR tool?
The link for the SDK Builder works fine and I could generate a configuration for the microcontroller and use it in IAR. But I am looking for free aternative SDK to IAR.
Saeid
2,624 次查看
Carlos_Mendoza
Hi Saeid,
There should not be a download link since the SDK package needs to be built specifically for your processor, evaluation board, OS, IDE and with the needed middleware in order to download it. This seems to be a problem with the webpage, I will report is to our web team.
If you want to use the SDK with IAR then you should select IAR as IDE in the configuration settings:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
2,624 次查看
Carlos_Mendoza
Hi Saeid,
Which error do you get while trying to download it?
Are downloading the SDK package from this page?
Welcome to MCUXpresso | MCUXpresso Config Tools
Please take a look at this guide on how to generate a SDK package:
https://community.nxp.com/docs/DOC-333304
Hope it helps!
Carlos Mendoza
