RDK-Demo Controller
RDK-Demo Controller
8,760 次查看
burak_
I have installed RDK-demo controller on my windows 10 laptop. But when ı try to run program, nothing happens. Program window does not open. In task manager, the task is running. I tried to run it as administrator, nothing has changed. Who can help me solving this issue?
5 回复数
7,578 次查看
Iktler
Are there any new solutions? I had exactly the same problem...
8,743 次查看
longfeiwang
Do you mean it can't be programmed? Or it doesn't run after programming?
8,739 次查看
burak_
I mean, I cannot open the GUI. When ı double click on icon, the application does not open but it is running on background, ı can see in task manager.
8,737 次查看
longfeiwang
You need to install the correct version of the matlab runtime environment and set the correct TFTP directory, then you can run app.exe normally.
8,708 次查看
marmar
I have the same problem. Where should I set the right TFTP directory?
