uart/serial problem with ls1046ardb
rans
Senior Contributor I
We are using ls1046ardb, and the serial connection is received from console usb output.
The problem is that the serial does not work well (whether in Linux or uboot):
console shows the previous character so although a new character is pressed. It makes it really difficult to work with the serial. Doing ssh works just fine.
Thanks for any suggestion
rans
I am using linux machine,
anyway, doing load unload module cdc_acm.ko or just PC reboot , solved the issue
Oswalag
Are you using a windows host computer?
rans
%3CLINGO-SUB%20id%3D%22lingo-sub-1868941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Euart%2Fserial%20problem%20with%20ls1046ardb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWe%20are%20using%20ls1046ardb%2C%20and%20the%20serial%20connection%20is%20received%20from%20console%20usb%20output.%3C%2FP%3E%3CP%3EThe%20problem%20is%20that%20the%20serial%20does%20not%20work%20well%20(whether%20in%20Linux%20or%20uboot)%3A%3C%2FP%3E%3CP%3Econsole%20shows%20the%20previous%20character%20so%20although%20a%20new%20character%20is%20pressed.%20It%20makes%20it%20really%20difficult%20to%20work%20with%20the%20serial.%20Doing%20ssh%20works%20just%20fine.%3C%2FP%3E%3CP%3EThanks%20for%20any%20suggestion%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20uart%2Fserial%20problem%20with%20ls1046ardb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20linux%20machine%2C%3C%2FP%3E%3CP%3Eanyway%2C%20doing%20load%20unload%20module%20cdc_acm.ko%20or%20just%20PC%20reboot%20%2C%20solved%20the%20issue%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1874878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20uart%2Fserial%20problem%20with%20ls1046ardb%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20a%20windows%20host%20computer%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
