stressapptest error on ls2084a
5,549件の閲覧回数
QiujuYe
Hi FAEs,
I use stressapptest tool to test memory on LS2084a, but have errors, then I use EDAC to show, there is no ecc errors, the log is as followings, please give some advice to me, thanks very much.
root@buildroot(LSDK)# stressapptest -s 60 0 -M 5424 -C 4 -m 4
1970/01/01-00:06:27(UTC) Log: Commandline - stressapptest -s 60 -M 5424 -C 4 -m 4
1970/01/01-00:06:27(UTC) Stats: SAT revision 1.0.9_autoconf, 64 bit binary
1970/01/01-00:06:27(UTC) Log: root @ fbubuntu on Mon Oct 25 07:22:34 UTC 2021 from open source release
1970/01/01-00:06:27(UTC) Log: 1 nodes, 8 cpus.
1970/01/01-00:06:27(UTC) Log: Prefer plain malloc memory allocation.
1970/01/01-00:06:27(UTC) Log: Using mmap() allocation at 0xfffe367c4000.
1970/01/01-00:06:27(UTC) Stats: Starting SAT, 5424M, 60 seconds
1970/01/01-00:06:28(UTC) Log: region number 7 exceeds region count 1
1970/01/01-00:06:28(UTC) Log: Region mask: 0x1
1970/01/01-00:06:34(UTC) Report Error: miscompare : DIMM Unknown : 1 : 7s
1970/01/01-00:06:34(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff6062fca8(0xf202fcad:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:38(UTC) Log: Seconds remaining: 50
1970/01/01-00:06:38(UTC) Report Error: miscompare : DIMM Unknown : 1 : 11s
1970/01/01-00:06:38(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff120d2fd8(0xd32d2fdd:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:44(UTC) Report Error: miscompare : DIMM Unknown : 1 : 17s
1970/01/01-00:06:44(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe5d105ff8(0x80e0105ffd:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:48(UTC) Log: Seconds remaining: 40
1970/01/01-00:06:49(UTC) Report Error: miscompare : DIMM Unknown : 1 : 22s
1970/01/01-00:06:49(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffed1138348(0x80b9f3834d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:50(UTC) Report Error: miscompare : DIMM Unknown : 1 : 23s
1970/01/01-00:06:50(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe5e7132e8(0x8107f132ed:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:51(UTC) Report Error: miscompare : DIMM Unknown : 1 : 24s
1970/01/01-00:06:51(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff04f486c8(0x8146d486cd:DIMM Unknown): read:0xffffeefffffffeff, reread:0xffffeefffffffeff expected:0xfffffefffffffeff
1970/01/01-00:06:51(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe921c85d8(0x8103fc85dd:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:54(UTC) Report Error: miscompare : DIMM Unknown : 1 : 27s
1970/01/01-00:06:54(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffea0980388(0x814f78038d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:56(UTC) Report Error: miscompare : DIMM Unknown : 1 : 29s
1970/01/01-00:06:56(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff3f1ad588(0x80853ad58d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:56(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe722bc598(0xe8ebc59d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:57(UTC) Report Error: miscompare : DIMM Unknown : 1 : 30s
1970/01/01-00:06:57(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff24850bc8(0x8132650bcd:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:57(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffebcd8ba78(0x810ab8ba7d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:57(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff2d852b28(0x8152652b2d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:58(UTC) Log: Seconds remaining: 30
1970/01/01-00:06:58(UTC) Report Error: miscompare : DIMM Unknown : 1 : 31s
1970/01/01-00:06:58(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe5e6be248(0x8107ebe24d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:58(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff54502e98(0x80bdb02e9d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:06:59(UTC) Report Error: miscompare : DIMM Unknown : 1 : 32s
1970/01/01-00:06:59(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff0b9e37c8(0x80dd7e37cd:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Report Error: miscompare : DIMM Unknown : 1 : 33s
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe59f73788(0x814e37378d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff33107788(0x811630778d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff23736f48(0x80b7536f4d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff7c6eec68(0x81110eec6d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe3ab3cb98(0x809af3cb9d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:00(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff531cc148(0xd27cc14d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:01(UTC) Report Error: miscompare : DIMM Unknown : 1 : 34s
1970/01/01-00:07:01(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffef35dcaa8(0x8168fdcaad:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:01(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffee61a2e58(0x81701a2e5d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:02(UTC) Report Error: miscompare : DIMM Unknown : 1 : 35s
1970/01/01-00:07:02(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe667c5298(0x81089c529d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:02(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe687e9d28(0xa17e9d2d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:02(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe5b69d588(0xdc29d58d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:03(UTC) Report Error: miscompare : DIMM Unknown : 1 : 36s
1970/01/01-00:07:03(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe73b2cfa8(0xa952cfad:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:03(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xfffe837bb648(0x81133bb64d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:03(UTC) Hardware Error: miscompare on CPU 4(0x10) at 0xffff875dcc78(0x989dcc7d:DIMM Unknown): read:0xffffefffffffffff, reread:0xffffefffffffffff expected:0xffffffffffffffff
1970/01/01-00:07:08(UTC) Log: Seconds remaining: 20
1970/01/01-00:07:18(UTC) Log: Seconds remaining: 10
1970/01/01-00:07:29(UTC) Log: Thread 3 found 83 hardware incidents
1970/01/01-00:07:29(UTC) Stats: Found 83 hardware incidents
1970/01/01-00:07:29(UTC) Stats: Completed: 668080.00M in 61.50s 10862.52MB/s, with 83 hardware incidents, 0 errors
1970/01/01-00:07:29(UTC) Stats: Memory Copy: 668080.00M at 11134.07MB/s
1970/01/01-00:07:29(UTC) Stats: File Copy: 0.00M at 0.00MB/s
1970/01/01-00:07:29(UTC) Stats: Net Copy: 0.00M at 0.00MB/s
1970/01/01-00:07:29(UTC) Stats: Data Check: 0.00M at 0.00MB/s
1970/01/01-00:07:29(UTC) Stats: Invert Data: 0.00M at 0.00MB/s
1970/01/01-00:07:29(UTC) Stats: Disk: 0.00M at 0.00MB/s
1970/01/01-00:07:29(UTC) Status: FAIL - test discovered HW problems
root@buildroot(LSDK)# dmesg | grep -i -e edac -e ecc
[ 1.275836] EDAC MC: Ver: 3.0.0
[ 1.275870] EDAC DEBUG: edac_mc_sysfs_init: device mc created
[ 1.822882] EDAC DEBUG: edac_mc_alloc: allocating 1936 bytes for mci data (4 ranks, 4 csrows/channels)
[ 1.822901] EDAC DEBUG: edac_mc_add_mc_with_groups:
[ 1.822904] EDAC DEBUG: edac_create_sysfs_mci_device: creating bus mc0
[ 1.822919] EDAC DEBUG: edac_create_sysfs_mci_device: creating device mc0
[ 1.822946] EDAC DEBUG: edac_create_sysfs_mci_device: creating dimm0, located at csrow 0 channel 0
[ 1.822970] EDAC DEBUG: edac_create_dimm_object: creating rank/dimm device rank0
[ 1.822972] EDAC DEBUG: edac_create_csrow_object: creating (virtual) csrow node csrow0
[ 1.823014] EDAC MC0: Giving out device to module fsl_ddr_edac controller fsl_mc_err: DEV fsl_mc_err (INTERRUPT)
[ 1.823041] fsl_ddr_edac acquired irq 99 for MC
[ 1.823042] fsl_ddr_edac MC err registered
[ 1.823064] EDAC DEBUG: edac_mc_alloc: allocating 1936 bytes for mci data (4 ranks, 4 csrows/channels)
[ 1.823081] EDAC DEBUG: edac_mc_add_mc_with_groups:
[ 1.823083] EDAC DEBUG: edac_create_sysfs_mci_device: creating bus mc1
[ 1.823096] EDAC DEBUG: edac_create_sysfs_mci_device: creating device mc1
[ 1.823118] EDAC DEBUG: edac_create_sysfs_mci_device: creating dimm0, located at csrow 0 channel 0
[ 1.823141] EDAC DEBUG: edac_create_dimm_object: creating rank/dimm device rank0
[ 1.823143] EDAC DEBUG: edac_create_csrow_object: creating (virtual) csrow node csrow0
[ 1.823176] EDAC MC1: Giving out device to module fsl_ddr_edac controller fsl_mc_err: DEV fsl_mc_err (INTERRUPT)
[ 1.823192] fsl_ddr_edac acquired irq 100 for MC
[ 1.823193] fsl_ddr_edac MC err registered
Best Regards
Qiuju.ye
6 返答(返信)
5,491件の閲覧回数
re88i6vilan
I had the same problem
5,542件の閲覧回数
yipingwang
Have you used QCVS DDRv tool to connect to your custom board to do optimization and validation to get the optimized DDR controller configuration parameters?
5,534件の閲覧回数
QiujuYe
Hi yipingwang,
Thanks for you replay. yes, we use QCVS DDRv too to test, the result seems good and some parametes are adjusted, but still have errors. I am confused why stressapptest tool test failed but EDAC can not capature the ecc errors. and wthether we can from the fail addresses to get the real physical addresses, all the error bit is bit 44, is a single bit, why ECC_FIX_EN bit can not correct?
Best Regards
Qiuju.ye
5,493件の閲覧回数
yipingwang
Do you use Rev 1.0 or Rev 1.1 processor.
It seems that you didn't  implement A-010679, the impact is as what you described.
A-010679: RCW[7] must be set to 1
Affects: GEN
Description: RCW[7] is a reserved bit and it should normally be cleared to 0. However, this bit has to be set to 1.
Impact: Data corruption could be observed if the workaround is not implemented.
Workaround: RCW[7] must be set to 1.
Fix plan: Fixed in Rev 1.1
5,483件の閲覧回数
QiujuYe
hi yipingwang,
Thanks for your reply.  I use lsdk1812 to build image,  I am not clear what you mean, where to find A-010679 and Rev 1.0 or Rev 1.1 processor?  can you explain clearly, thanks very much.
Best Regards
Qiuju.ye
5,447件の閲覧回数
yipingwang
Would you please provide your u-boot console log?
