flexbuild_ Lsdk2108 failed to compile linux-5.10-rt ..?
hongyuanz
[root@fbubuntu flexbuild_lsdk2108]$ flex-builder -c linux:linux-5.10-rt -a arm64
COMPONENT: linux:linux-5.10-rt
Invalid component name: linux:linux-5.10-rt
Valid app component:
restool tsntool flib fmlib fmc spc dpdk ovs_dpdk pktgen_dpdk vpp aiopsl ceetm dce eth_config gpp_aioptool qbman_userspace aquantia_firmware_utility wayland wayland_protocols gpulib libdrm weston xserver imxvpu cst openssl keyctl_caam crconf optee optee_os optee_client optee_test libpkcs11 secure_obj iperf cjson docker_ce uuu ros
Valid linux component:
linux cryptodev_linux lttng_modules mdio_proxy_module
Valid firmware component:
atf rcw uboot uefi_bin mc_bin mc_utils fm_ucode qe_ucode phy_cortina phy_inphi pfe_bin ddr_phy_bin dp_firmware_cadence
Valid eIQ component:
armcl armnn caffe flatbuffer onnx onnxruntime opencv protobuf tflite
yipingwang
Please use the following command.
$ flex-builder -c linux:linux:LSDK-21.08-RT
