Eventually got to start debugging our LS1021A based porotype.
it fails very early on writing to ddr->eor (0x108_0c00).
/* disable the re-ordering in DDRC */
ddr_out32(&ddr->eor, DDR_EOR_RD_REOD_DIS | DDR_EOR_WD_REOD_DIS);
I do not find a description of this register in the LS1021A manual Rev 3.1.
I can access register sets such as DCFG, IFC but not the DDR controller. Though, it is not disabled as per DCFG_CCSR_DEVDISR5. My ls1021a-iot has not this problem.
Has anybody seen this issue?
Solved! Go to Solution.
We did find the issue. The DDR reference clock was set to DDRCLK instead of DIFF SYSCLK. After that we had access to the DDR registers
