UBOOT Static IP Address Configuration Not Sticking for LS1028ARDB
joy_t
What is the best way to configure a static IP address on boot for the LS1028ARDB? I've set a couple UBOOT variables to SPI flash, but I'm not seeing the ethernet device be brought up and configured with an IP address after being booted to TinyLinux from SD.
=> setenv ipaddr 192.168.3.201
=> setenv serverip 192.168.3.200
=> setenv netmask 255.255.255.0
I've also noticed that eth0 is getting renamed to eno0 and the MAC address of the device changes between boots. Configuring via /etc/network/interfaces does not work either because file changes do not persist between boots.
Any guidance on this issue would be great, thank you.
Tags (2)
June_Lu
Insert a SD card in the LS1028ARDB.
Automatically download and deploy LSDK images
flex-installer -i auto -m ls1028ardb -d sd
Then you will get a rootfs in the SD card partition 4.
Modify the partition 4 /etc/network/interfaces.
Add information below:
auto eno0
iface eno0 inet static
        address 192.168.8.9
        gatway 192.168.8.1
        dns-nameservers 8.8.8.8.8.8.4.4
The eno0 will be active when the ls1028ardb boot up.
The address will be set 192.168.8.9
And the netmask, gateway, dsn would be set follow the example.
June_Lu
June_Lu
auto eno0
        address 192.168.8.9
        gatway 192.168.8.1
joy_t
Thank you! These instructions worked for me with a couple additional steps:
  • Before running the flex-installer:
    • Run umount and fsck on any partition already mounted
    • Change each partition from FAT to EXT4 with mkfs.ext4
    • Resize partition 4 to be at least 4 GB with fdisk
  • After resetting the board:
    • Stop autoboot and enter UBOOT
    • Make sure bootargs has root=<partition 4> (for me, this was /dev/mmcblk0p4)
    • Reset board
%3CLINGO-SUB%20id%3D%22lingo-sub-2022035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUBOOT%20Static%20IP%20Address%20Configuration%20Not%20Sticking%20for%20LS1028ARDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EWhat%20is%20the%20best%20way%20to%20configure%20a%20static%20IP%20address%20on%20boot%20for%20the%20LS1028ARDB%3F%20I've%20set%20a%20couple%20UBOOT%20variables%20to%20SPI%20flash%2C%20but%20I'm%20not%20seeing%20the%20ethernet%20device%20be%20brought%20up%20and%20configured%20with%20an%20IP%20address%20after%20being%20booted%20to%20TinyLinux%20from%20SD.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%3D%26gt%3B%20setenv%20ipaddr%20192.168.3.201%0A%3D%26gt%3B%20setenv%20serverip%20192.168.3.200%0A%3D%26gt%3B%20setenv%20netmask%20255.255.255.0%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EI've%20also%20noticed%20that%20eth0%20is%20getting%20renamed%20to%20eno0%20and%20the%20MAC%20address%20of%20the%20device%20changes%20between%20boots.%20Configuring%20via%20%2Fetc%2Fnetwork%2Finterfaces%20does%20not%20work%20either%20because%20file%20changes%20do%20not%20persist%20between%20boots.%3C%2FP%3E%3CP%3EAny%20guidance%20on%20this%20issue%20would%20be%20great%2C%20thank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2025035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UBOOT%20Static%20IP%20Address%20Configuration%20Not%20Sticking%20for%20LS1028ARDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you!%20These%20instructions%20worked%20for%20me%20with%20a%20couple%20additional%20steps%3A%3C%2FP%3E%3CUL%3E%3CLI%3EBefore%20running%20the%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eflex-installer%3C%2FFONT%3E%3A%3CUL%3E%3CLI%3ERun%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eumount%3C%2FFONT%3E%20and%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efsck%3C%2FFONT%3E%20on%20any%20partition%20already%20mounted%3C%2FLI%3E%3CLI%3EChange%20each%20partition%20from%20FAT%20to%20EXT4%20with%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Emkfs.ext4%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3EResize%20partition%204%20to%20be%20at%20least%204%20GB%20with%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efdisk%3C%2FFONT%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3EAfter%20resetting%20the%20board%3A%3CUL%3E%3CLI%3EStop%20autoboot%20and%20enter%20UBOOT%3C%2FLI%3E%3CLI%3EMake%20sure%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Ebootargs%3C%2FFONT%3E%20has%26nbsp%3B%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%3D%3CPARTITION%204%3D%22%22%3E%3C%2FPARTITION%3E%3C%2FFONT%3E%20(for%20me%2C%20this%20was%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2Fdev%2Fmmcblk0p4%3C%2FFONT%3E)%3C%2FLI%3E%3CLI%3EReset%20board%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UBOOT%20Static%20IP%20Address%20Configuration%20Not%20Sticking%20for%20LS1028ARDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22interfaces.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22interfaces.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318559iE99B76F4B1E344C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22interfaces.png%22%20alt%3D%22interfaces.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ifconfig.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ifconfig.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318561i80A69EAA1D2EB3AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ifconfig.png%22%20alt%3D%22ifconfig.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20UBOOT%20Static%20IP%20Address%20Configuration%20Not%20Sticking%20for%20LS1028ARDB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EInsert%20a%20SD%20card%20in%20the%20LS1028ARDB.%3C%2FP%3E%0A%3CP%3EAutomatically%20download%20and%20deploy%20LSDK%20images%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eflex-installer%20-i%20auto%20-m%20ls10%3C%2FSPAN%3E%3CSPAN%3E28%3C%2FSPAN%3E%3CSPAN%3Eardb%20-d%20%3C%2FSPAN%3E%3CSPAN%3Esd%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20you%20will%20get%20a%20rootfs%20in%20the%20SD%20card%20partition%204.%3C%2FP%3E%0A%3CP%3EModify%20the%20partition%204%20%2Fetc%2Fnetwork%2Finterfaces.%3C%2FP%3E%0A%3CP%3EAdd%20information%20below%3A%3C%2FP%3E%0A%3CP%3Eauto%20eno0%3C%2FP%3E%0A%3CP%3Eiface%20eno0%20inet%20static%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20address%20192.168.8.9%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20netmask%20255.255.255.0%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gatway%20192.168.8.1%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20dns-nameservers%208.8.8.8.8.8.4.4%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20eno0%20will%20be%20active%20when%20the%20ls1028ardb%20boot%20up.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThe%20address%20will%20be%20set%20%3C%2FSPAN%3E%3CSPAN%3E192.168.8.9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnd%20the%20netmask%2C%20gateway%2C%20dsn%20would%20be%20set%20follow%20the%20example.%3C%2FP%3E%3C%2FLINGO-BODY%3E
