UBOOT Static IP Address Configuration Not Sticking for LS1028ARDB
3,188件の閲覧回数
joy_t
What is the best way to configure a static IP address on boot for the LS1028ARDB? I've set a couple UBOOT variables to SPI flash, but I'm not seeing the ethernet device be brought up and configured with an IP address after being booted to TinyLinux from SD.
=> setenv ipaddr 192.168.3.201
=> setenv serverip 192.168.3.200
=> setenv netmask 255.255.255.0
I've also noticed that eth0 is getting renamed to eno0 and the MAC address of the device changes between boots. Configuring via /etc/network/interfaces does not work either because file changes do not persist between boots.
Any guidance on this issue would be great, thank you.
タグ(2)
3,156件の閲覧回数
June_Lu
Insert a SD card in the LS1028ARDB.
Automatically download and deploy LSDK images
flex-installer -i auto -m ls1028ardb -d sd
Then you will get a rootfs in the SD card partition 4.
Modify the partition 4 /etc/network/interfaces.
Add information below:
auto eno0
iface eno0 inet static
        address 192.168.8.9
        gatway 192.168.8.1
        dns-nameservers 8.8.8.8.8.8.4.4
The eno0 will be active when the ls1028ardb boot up.
The address will be set 192.168.8.9
And the netmask, gateway, dsn would be set follow the example.
3 返答(返信)
3,155件の閲覧回数
June_Lu
3,157件の閲覧回数
June_Lu
auto eno0
        address 192.168.8.9
        gatway 192.168.8.1
3,135件の閲覧回数
joy_t
Thank you! These instructions worked for me with a couple additional steps:
  • Before running the flex-installer:
    • Run umount and fsck on any partition already mounted
    • Change each partition from FAT to EXT4 with mkfs.ext4
    • Resize partition 4 to be at least 4 GB with fdisk
  • After resetting the board:
    • Stop autoboot and enter UBOOT
    • Make sure bootargs has root=<partition 4> (for me, this was /dev/mmcblk0p4)
    • Reset board
%3CLINGO-SUB%20id%3D%22lingo-sub-2022035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUBOOT%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%A7%8B%E6%88%90%E3%81%8CLS1028ARDB%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3ELS1028ARDB%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%9C%80%E9%81%A9%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEUBOOT%E5%A4%89%E6%95%B0%E3%82%92SPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81SD%E3%81%8B%E3%82%89TinyLinux%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%3D%26gt%3B%20setenv%20ipaddr%20192.168.3.201%0A%3D%26gt%3B%20setenv%20serverip%20192.168.3.200%0A%3D%26gt%3B%20setenv%20netmask%20255.255.255.0%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81eth0%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8Ceno0%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E3%83%96%E3%83%BC%E3%83%88%E9%96%93%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%82%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%2Fetc%2Fnetwork%2Finterfaces%20%E3%81%AB%E3%82%88%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%82%82%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E3%83%96%E3%83%BC%E3%83%88%E9%96%93%E3%81%A7%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2025035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AUBOOT%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%A7%8B%E6%88%90%E3%81%8CLS1028ARDB%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%A7%E7%A7%81%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%83%8D%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eflex-installer%3C%2FFONT%3E%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%3A%3CUL%3E%3CLI%3E%E6%97%A2%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eumount%3C%2FFONT%3E%20%E3%81%A8%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efsck%3C%2FFONT%3E%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Emkfs.ext4%3C%2FFONT%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%84%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92FAT%E3%81%8B%E3%82%89EXT4%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%204%20%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efdisk%3C%2FFONT%3E%20%E3%81%A7%204%20GB%20%E4%BB%A5%E4%B8%8A%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%3A%3CUL%3E%3CLI%3E%E8%87%AA%E5%8B%95%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81UBOOT%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Ebootargs%E3%81%8C%3C%2FFONT%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%20%3D%20%3CPARTITION%204%3D%22%22%3E%3C%2FPARTITION%3E%3C%2FFONT%3E%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2F%20dev%20%2F%20mmcblk0p4%3C%2FFONT%3E%E3%81%A7%E3%81%97%E3%81%9F)%3C%2FLI%3E%3CLI%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AUBOOT%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%A7%8B%E6%88%90%E3%81%8CLS1028ARDB%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22interfaces.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22interfaces.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318559iE99B76F4B1E344C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22interfaces.png%22%20alt%3D%22interfaces.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ifconfig.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ifconfig.png%22%20style%3D%22width%3A%20903px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318561i80A69EAA1D2EB3AF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ifconfig.png%22%20alt%3D%22ifconfig.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AUBOOT%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%A7%8B%E6%88%90%E3%81%8CLS1028ARDB%E3%81%AB%E5%9B%BA%E5%9F%B7%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92LS1028ARDB%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ELSDK%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eflex-installer%20-i%20auto%20-m%20ls10%3C%2FSPAN%3E%3CSPAN%3E28%3C%2FSPAN%3E%3CSPAN%3Eardb%20-d%20%3C%2FSPAN%3E%3CSPAN%3Esd%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B34%E3%81%ABrootfs%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%204%20%2Fetc%2Fnetwork%2Finterfaces%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Eauto%20eno0%3C%2FP%3E%0A%3CP%3Eiface%20eno0%20inet%E9%9D%99%E7%9A%84%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20192.168.8.9%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20netmask%20255.255.255.0%3C%2FP%3E%0A%3CP%3E%E3%82%AC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4192.168.8.1%3C%2FP%3E%0A%3CP%3EDNS%E3%83%8D%E3%83%BC%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%208.8.8.8.8.4.4%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eeno0%20%E3%81%AF%E3%80%81ls1028ardb%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E192.168.8.9%3C%2FSPAN%3E%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%E3%80%81%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%80%81dsn%20%E3%81%AF%E4%BE%8B%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
