Set Custom Hostname in LLDP SDK
pvsnsubhash
I want to change the hostname of the LLDP SDK for NXP LX2160ARBD Board. I tried using "hostname" and "hostname_pn-base-files" in local.conf, but after building it shows the default hostname. I even tried creating a base-files recipe with a bbappend to modify hostname and hosts file in my custom layer, even that didn't work.. What else can be done?
PVSN Subhash
pvsnsubhash
I have resolved this by using the parameter HOST_NAME = "CUSTOM_HOSTNAME" in the respective distro's bb file, in my case it is ls-image-main.
I created a ls-image-main.bbappend in my custom layer and added this line in that file and after building the distro recipe, host name change was reflected in the image.
PVSN Subhash
June_Lu
If you want to add custom machine in the yocto, you could refer to
https://docs.nxp.com/bundle/UG10081_LLDP_L6.1.55_2.2.0/page/topics/how_to_add_a_custom_machine_in_fl...
pvsnsubhash
PVSN Subhash
%3CLINGO-SUB%20id%3D%22lingo-sub-2112550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESet%20Custom%20Hostname%20in%20LLDP%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2112550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20want%20to%20change%20the%20hostname%20of%20the%20LLDP%20SDK%20for%20NXP%20LX2160ARBD%20Board.%20I%20tried%20using%20%22hostname%22%20and%20%22hostname_pn-base-files%22%20in%20local.conf%2C%20but%20after%20building%20it%20shows%20the%20default%20hostname.%20I%20even%20tried%20creating%20a%20base-files%20recipe%20with%20a%20bbappend%20to%20modify%20hostname%20and%20hosts%20file%20in%20my%20custom%20layer%2C%20even%20that%20didn't%20work..%20What%20else%20can%20be%20done%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Set%20Custom%20Hostname%20in%20LLDP%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20resolved%20this%20by%20using%20the%20parameter%26nbsp%3BHOST_NAME%20%3D%20%22CUSTOM_HOSTNAME%22%20in%20the%20respective%20distro's%20bb%20file%2C%20in%20my%20case%20it%20is%20ls-image-main.%26nbsp%3B%3C%2FP%3E%3CP%3EI%20created%20a%20ls-image-main.bbappend%20in%20my%20custom%20layer%20and%20added%20this%20line%20in%20that%20file%20and%20after%20building%20the%20distro%20recipe%2C%20host%20name%20change%20was%20reflected%20in%20the%20image.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2115007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Set%20Custom%20Hostname%20in%20LLDP%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2115007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EIf%20you%20want%20to%20add%20custom%20machine%20in%20the%20yocto%2C%20you%20could%20refer%20to%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10081_LLDP_L6.1.55_2.2.0%2Fpage%2Ftopics%2Fhow_to_add_a_custom_machine_in_flexbuild_based_on_.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10081_LLDP_L6.1.55_2.2.0%2Fpage%2Ftopics%2Fhow_to_add_a_custom_machine_in_flexbuild_based_on_.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E
