Inquiry Regarding JTAG Debugger Support for LX2082A
rahul1512p
Dear NXP Support Team,
I am developing a custom board based on the NXP LX2082A processor and am currently planning the hardware bring-up and debugging setup.
I would like to clarify whether SEGGER J-Link is officially supported for the following tasks on the LX2082A:
  • Initial board bring-up
  • JTAG debugging
  • Bare-metal debugging
  • TF-A and U-Boot debugging
  • Linux kernel debugging
  • Flash programming (if supported)
My development environment is Linux, and I plan to develop and build all software on a Linux host.
Could you please advise:
  1. Is SEGGER J-Link officially supported for the LX2082A?
  2. If yes, which J-Link models are supported?
  3. Are there any limitations compared to NXP-recommended debug solutions?
  4. If J-Link is not recommended, could you please suggest the officially supported hardware debugger(s) for the LX2082A?
I would appreciate any documentation or application notes related to JTAG debugging and board bring-up for the LX2082A.
Thank you for your assistance. I look forward to your guidance.
Kind regards.
June_Lu
1.  CodeWarrior function will stop.
2. No.
3. No. Need a valid license.
4. Linux debug could work without JTAG debugging, but DDR validation on each board, and first time flash should use the JTAG debugger(CW TAP) with CodeWarrior IDE.
June_Lu
The NXP officially supported debugger is CWTAP.
You can use codewarrior Developer Suite Level for your application.
You can also download  Evaluation Edition(free-trial) from below link but it has 30-day time restriction
Every customer account (email address) can download the Evaluation Edition from the link below.
Please select “DOWNLOAD EVAL”.
https://www.nxp.com/design/design-center/software/development-software/codewarrior-development-tools...
Please find the useful docuemnttation below:
ARMv8_Targeting_Manual.pdf
CodeWarrior TAP Probe User Guide
Layerscape Linux SDK User Guide
rahul1512p
Hello NXP Support,
I have a question regarding the 30-day CodeWarrior Evaluation Edition.
After the evaluation period expires:
  1. Will JTAG connection (using CW TAP) still work, or does CodeWarrior stop functioning completely?
  2. Will RCW generation/programming and flash programming still be available without a paid license?
  3. Can QCVS (QorIQ Configuration and Validation Suite) continue to be used after the trial expires, or does it also require a valid CodeWarrior license?
  4. For customers using only Linux command-line tools (U-Boot, Yocto, OpenOCD, etc.), is purchasing CodeWarrior recommended only for JTAG debugging, or is it mandatory for board bring-up?
I would appreciate your clarification on which features remain available after the evaluation period.
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2393956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EInquiry%20Regarding%20JTAG%20Debugger%20Support%20for%20LX2082A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2393956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EDear%20NXP%20Support%20Team%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20am%20developing%20a%20custom%20board%20based%20on%20the%20NXP%20LX2082A%20processor%20and%20am%20currently%20planning%20the%20hardware%20bring-up%20and%20debugging%20setup.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20would%20like%20to%20clarify%20whether%20SEGGER%20J-Link%20is%20officially%20supported%20for%20the%20following%20tasks%20on%20the%20LX2082A%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3EInitial%20board%20bring-up%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EJTAG%20debugging%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EBare-metal%20debugging%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ETF-A%20and%20U-Boot%20debugging%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3ELinux%20kernel%20debugging%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EFlash%20programming%20(if%20supported)%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EMy%20development%20environment%20is%20Linux%2C%20and%20I%20plan%20to%20develop%20and%20build%20all%20software%20on%20a%20Linux%20host.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20you%20please%20advise%3A%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3EIs%20SEGGER%20J-Link%20officially%20supported%20for%20the%20LX2082A%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EIf%20yes%2C%20which%20J-Link%20models%20are%20supported%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EAre%20there%20any%20limitations%20compared%20to%20NXP-recommended%20debug%20solutions%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EIf%20J-Link%20is%20not%20recommended%2C%20could%20you%20please%20suggest%20the%20officially%20supported%20hardware%20debugger(s)%20for%20the%20LX2082A%3F%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20would%20appreciate%20any%20documentation%20or%20application%20notes%20related%20to%20JTAG%20debugging%20and%20board%20bring-up%20for%20the%20LX2082A.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EThank%20you%20for%20your%20assistance.%20I%20look%20forward%20to%20your%20guidance.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EKind%20regards.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Inquiry%20Regarding%20JTAG%20Debugger%20Support%20for%20LX2082A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394136%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EThe%20NXP%20officially%20supported%20debugger%20is%20CWTAP.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EYou%20can%20use%20codewarrior%20Developer%20Suite%20Level%20for%20your%20application.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EYou%20can%20also%20download%26nbsp%3B%26nbsp%3BEvaluation%20Edition(free-trial)%26nbsp%3Bfrom%20below%20link%26nbsp%3Bbut%20it%20has%2030-day%20time%20restriction%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EEvery%20customer%20account%20(email%20address)%20can%20download%20the%20Evaluation%20Edition%20from%20the%20link%20below.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EPlease%20select%20%E2%80%9CDOWNLOAD%20EVAL%E2%80%9D.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fcodewarrior-development-tools%2Fcodewarrior-network-applications%2Fcodewarrior-development-suites-for-networked-applications%3ACW-DS-NETAPPS%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fcodewarrior-development-tools%2Fcodewarrior-network-applications%2Fcodewarrior-development-suites-for-networked-applications%3ACW-DS-NETAPPS%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3EPlease%20find%20the%20useful%20docuemnttation%20below%3A%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2Fcw-qoriq%2F6303%2F1%2FARMv8_Targeting_Manual_Flash_Programmer.pdf%22%20target%3D%22_blank%22%3EARMv8_Targeting_Manual.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FCWTAPUG.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECodeWarrior%20TAP%20Probe%20User%20Guide%3C%2FA%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10381%26amp%3Blocation%3Dnull%26amp%3BisHTMLorPDF%3DHTML%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELayerscape%20Linux%20SDK%20User%20Guide%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3EClarification%20on%20CodeWarrior%20License%20After%2030-Day%20Evaluation%20(CW%20TAP%20%2F%20QCVS%20%2F%20QCS)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3EHello%20NXP%20Support%2C%3C%2FP%3E%3CP%3EI%20have%20a%20question%20regarding%20the%20%3CSTRONG%3E30-day%20CodeWarrior%20Evaluation%20Edition%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EAfter%20the%20evaluation%20period%20expires%3A%3C%2FP%3E%3COL%3E%3CLI%3EWill%20%3CSTRONG%3EJTAG%20connection%20(using%20CW%20TAP)%3C%2FSTRONG%3E%20still%20work%2C%20or%20does%20CodeWarrior%20stop%20functioning%20completely%3F%3C%2FLI%3E%3CLI%3EWill%20%3CSTRONG%3ERCW%20generation%2Fprogramming%3C%2FSTRONG%3E%20and%20%3CSTRONG%3Eflash%20programming%3C%2FSTRONG%3E%20still%20be%20available%20without%20a%20paid%20license%3F%3C%2FLI%3E%3CLI%3ECan%20%3CSTRONG%3EQCVS%20(QorIQ%20Configuration%20and%20Validation%20Suite)%3C%2FSTRONG%3E%20continue%20to%20be%20used%20after%20the%20trial%20expires%2C%20or%20does%20it%20also%20require%20a%20valid%20CodeWarrior%20license%3F%3C%2FLI%3E%3CLI%3EFor%20customers%20using%20only%20Linux%20command-line%20tools%20(U-Boot%2C%20Yocto%2C%20OpenOCD%2C%20etc.)%2C%20is%20purchasing%20CodeWarrior%20recommended%20only%20for%20JTAG%20debugging%2C%20or%20is%20it%20mandatory%20for%20board%20bring-up%3F%3C%2FLI%3E%3C%2FOL%3E%3CP%3EI%20would%20appreciate%20your%20clarification%20on%20which%20features%20remain%20available%20after%20the%20evaluation%20period.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Inquiry%20Regarding%20JTAG%20Debugger%20Support%20for%20LX2082A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%26nbsp%3B%3CSPAN%3E%26nbsp%3BCodeWarrior%20function%20will%20stop.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E2.%20No.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3.%20No.%20Need%20a%20valid%20license.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E4.%20Linux%20debug%20could%20work%20without%20JTAG%20debugging%2C%20but%20DDR%20validation%20on%20each%20board%2C%20and%20first%20time%20flash%20should%20use%20the%20JTAG%20debugger(CW%20TAP)%20with%20CodeWarrior%20IDE.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
