Set CPU frequency not working
2,381 次查看
noahw
I am following directions on this page (https://docs.nxp.com/bundle/GUID-39A0A446-70E5-4ED7-A580-E7508B61A5F1/page/GUID-40BE9AD5-DF6B-4D99-A...) about switching CPU frequency by writing to a file in /sys.
When I try to run the command
echo 799999 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
I see the following error:
-bash: echo: write error: Invalid argument
What am I doing wrong? I tried other values like 300000, and I also tried putting the value in quotes, using the -n flag for echo, etc. I used chmod to add write permission to scaling_setspeed. Is there something else I need to do?
2,335 次查看
June_Lu
In the default LSDK2108.
root@localhost:~# cd /sys/devices/system/cpu/cpu0/cpufreq
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# ls
affected_cpus     cpuinfo_max_freq  cpuinfo_transition_latency  scaling_available_frequencies  scaling_cur_freq  scaling_governor  scaling_min_freq  stats
cpuinfo_cur_freq  cpuinfo_min_freq  related_cpus                scaling_available_governors    scaling_driver    scaling_max_freq  scaling_setspeed
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# cat scaling_available_governors
ondemand userspace performance
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# echo userspace > scaling_governor
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# cat scaling_cur_freq
600000
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# cat scaling_available_frequencies
1500000 1200000 750000 600000 375000 300000
root@localhost:/sys/devices/system/cpu/cpu0/cpufreq# echo 750000 > scaling_setspeed
750000
2,336 次查看
June_Lu
600000
750000
2,365 次查看
June_Lu
Please kindly share the MPU part number and SW version, thanks
2,351 次查看
noahw
@June_Lu This is the LS1028ARDB running LSDK 21.08, kernel 5.10.35.
%3CLINGO-SUB%20id%3D%22lingo-sub-2075588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AE%BE%E7%BD%AE%20CPU%20%E9%A2%91%E7%8E%87%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%8C%89%E7%85%A7%E6%AD%A4%E9%A1%B5%E9%9D%A2%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FGUID-39A0A446-70E5-4ED7-A580-E7508B61A5F1%2Fpage%2FGUID-40BE9AD5-DF6B-4D99-A3FB-5988A50DACA2.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FGUID-39A0A446-70E5-4ED7-A580-E7508B61A5F1%2Fpage%2FGUID-40BE9AD5-DF6B-4D99-A3FB-5988A50DACA2.html%3C%2FA%3E%20%EF%BC%89%E4%B8%8A%E7%9A%84%E8%AF%B4%E6%98%8E%EF%BC%8C%E9%80%9A%E8%BF%87%E5%86%99%E5%85%A5%20%2Fsys%20%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E6%9D%A5%E5%88%87%E6%8D%A2%20CPU%20%E9%A2%91%E7%8E%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%E6%97%B6%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3Eecho%20799999%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fcpu%2Fcpu0%2Fcpufreq%2Fscaling_setspeed%3C%2FPRE%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E-bash%EF%BC%9Aecho%EF%BC%9A%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%95%88%E5%8F%82%E6%95%B0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%85%B6%E4%BB%96%E5%80%BC%EF%BC%8C%E4%BE%8B%E5%A6%82%20300000%EF%BC%8C%E4%B9%9F%E5%B0%9D%E8%AF%95%E5%B0%86%E5%80%BC%E6%94%BE%E5%9C%A8%E5%BC%95%E5%8F%B7%E4%B8%AD%EF%BC%8C%E4%BD%BF%E7%94%A8%20-n%20%E6%A0%87%E5%BF%97%E8%BF%9B%E8%A1%8C%E5%9B%9E%E6%98%BE%E7%AD%89%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%20chmod%20%E4%B8%BA%20scaling_setspeed%20%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%86%99%E5%85%A5%E6%9D%83%E9%99%90%E3%80%82%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%81%9A%E5%85%B6%E4%BB%96%E4%BA%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2076361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E8%AE%BE%E7%BD%AE%20CPU%20%E9%A2%91%E7%8E%87%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2076361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%E8%BF%99%E6%98%AF%E8%BF%90%E8%A1%8C%20LSDK%2021.08%E3%80%81%E5%86%85%E6%A0%B8%205.10.35%20%E7%9A%84%20LS1028ARDB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E8%AE%BE%E7%BD%AE%20CPU%20%E9%A2%91%E7%8E%87%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%20MPU%20%E9%83%A8%E4%BB%B6%E5%8F%B7%E5%92%8C%20SW%20%E7%89%88%E6%9C%AC%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
