Ethernet setup on LS1028ARDB
已解决
跳至解决方案
1,517 次查看
noahw
I am trying to set up ethernet interface on LS1028ARDB as well. I run your shell script from https://community.nxp.com/t5/Layerscape/Switch-Setup-on-LS1028ARDB/m-p/2061701?attachment-id=18222 to bring the interfaces up, then follow the next steps. I do see the lines:
mscc_felix 0000:00:00.5 swp0: Link is Up -- 1Gbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): swp0: link becomes ready
However, when I try ping -c 5 -s 1 100.1.1.1, the ping fails and I get Destination Host Unreachable.
my output of `ip a` shows:
eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> with no ip address, and
swp0@eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> with ip address 100.1.1.29
Any ideas?
1 解答
1,453 次查看
noahw
Figured this out, I needed to run
dhclient eno0
在原帖中查看解决方案
2 回复数
1,462 次查看
yipingwang
1. Please check Kernel configuration file whether the following Kernel options are enabled.
~# zcat /proc/config.gz | grep CONFIG_MSCC_OCELOT_SWITCH
CONFIG_MSCC_OCELOT_SWITCH=y
~# zcat /proc/config.gz | grep CONFIG_NET_DSA_MSCC_FELIX
CONFIG_NET_DSA_MSCC_FELIX=y
~# zcat /proc/config.gz | grep CONFIG_FSL_ENETC_MDIO
CONFIG_FSL_ENETC_MDIO=y
Example – Single port configuration of the Felix DSA switch driver:
#!/bin/bash
# configure external switch interfaces
ip addr add 192.168.0.1/24 dev swp0
ip addr add 192.168.1.1/24 dev swp1
ip addr add 192.168.1.1/24 dev swp2
ip addr add 192.168.1.1/24 dev swp3
# master interface to be brought up first
ip link set eno2 up
# bring up the slave interfaces
ip link set swp0 up
ip link set swp1 up
ip link set swp2 up
ip link set swp3 up
Please refer to "8.6.3.3.4 Bridge mode" and "8.6.3.3.5 Gateway mode" in LSDK 21.08 user manual to configure switch ports in other mode.
1,454 次查看
noahw
dhclient eno0
%3CLINGO-SUB%20id%3D%22lingo-sub-2071472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1028ARDB%20%E4%B8%8A%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%AE%BE%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20LS1028ARDB%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E3%80%82%E6%88%91%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2FSwitch-Setup-on-LS1028ARDB%2Fm-p%2F2061701%3Fattachment-id%3D18222%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape%2FSwitch-Setup-on-LS1028ARDB%2Fmp%2F2061701%3Fattachment-id%3D18222%3C%2FA%3E%E8%BF%90%E8%A1%8C%E6%82%A8%E7%9A%84%20shell%20%E8%84%9A%E6%9C%AC%E6%9D%A5%E5%90%AF%E5%8A%A8%E6%8E%A5%E5%8F%A3%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%E3%80%82%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%EF%BC%9A%3C%2FP%3E%3CP%3Emscc_felix%200000%3A00%3A00.5%20swp0%EF%BC%9A%E9%93%BE%E8%B7%AF%E5%B7%B2%E5%90%AF%E5%8A%A8%20--%201Gbps%2F%E6%BB%A1%E9%80%9F%20-%20%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%20rx%2Ftx%3C%2FP%3E%3CP%3EIPv6%EF%BC%9AADDRCONF%EF%BC%88NETDEV_CHANGE%EF%BC%89%EF%BC%9Aswp0%EF%BC%9A%E9%93%BE%E8%B7%AF%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%20ping%20-c%205%20-s%201%20100.1.1.1%20%E6%97%B6%EF%BC%8Cping%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B9%B6%E6%98%BE%E7%A4%BA%E2%80%9C%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E2%80%9Cip%20a%E2%80%9D%E8%BE%93%E5%87%BA%E6%98%BE%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3Eeno2%EF%BC%9A%3CBROADCAST%3E%20%E6%B2%A1%E6%9C%89%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%B9%B6%E4%B8%94%3C%2FBROADCAST%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22mailto%3Aswp0%40eno2%3A%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eswp0%40eno2%3A%3C%2FA%3E%20%3CBROADCAST%3E%20IP%E5%9C%B0%E5%9D%80%E4%B8%BA100.1.1.29%3C%2FBROADCAST%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2076518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1028ARDB%20%E4%B8%8A%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%AE%BE%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2076518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%83%B3%E9%80%9A%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E8%B7%91%3C%2FP%3E%3CP%3Edhclient%20eno0%3C%2FP%3E%3C%2FLINGO-BODY%3E
