SPI sample code for LS1046A
1,557 次查看
DaT63
Hi all,
does anyone know if there is some sample C code that uses the SPI I/F not under Linux? Just bare C code?
Thanks in advance
标记 (2)
1,499 次查看
Oswalag
There are program examples in CW4NET for ARM. These examples contain .h files for eSDHC and qSPI. Use the following path:
C:\Freescale\CW4NET_v2020.06\CW_ARMv8\ARMv8\CodeWarrior_Examples
1,487 次查看
DaT63
thank you for the answer. I checked the folder you indicate but, apart of the usual hello word examples, I was not able to find anything that uses the SPI I/F
1,451 次查看
Oswalag
Unfortunately there isn't available a simple SPI c code, the available information can be found in the u-boot spi drivers or the linux driver according to the LSDKUG.
