Problem interfacing PCIe to UART (XR17V35X) with LS1043ARDB
TrinathK
Hi all,
      I am trying to interface XR17V354 (PCIe to 4 UARTs) with LS1043ARDB and the device sits on PCIe2. When i restart the board, booting gets stopped as show in the boot log attached.
When the device is not interfaced, booting happens successfully. Please help me with this issue.
Also let me know if any changes are required in DTSI file, Driver source file (attached for your reference) for proper working of XR17V354 interface.
Thanks in advance.
ufedor
In the provided log the XR17V354 is discovered and allocated properly.
Please check whether console output is switched to the XR17V354 port.
ufedor
