Power Connection to unused block
1,753 次查看
deepaknaiknavar
I am using LS1021 processor. This Processor has several blocks and its invidual supply rails like USB, Serdes, GPIO.
I have a basic question- If i am not using a USB block in my applixation, should i connect it to a power rail or leave it unconnected?
What is a better approach?
Deepak
标记 (1)
1,692 次查看
Pavel
Look at the LS1021a Design Checklist:
https://www.nxp.com/webapp/Download?colCode=AN4878&location=null&fasp=1&WT_TYPE=Application%20Notes&...
This document contains recommendation for the LS1021a pins connection if USB block or SERDES or GPIO are not used.
Pavel Chubakov
1,692 次查看
alexander_yakov
Typically, this information is explicitly specified in device datasheet. If it is not explicitly allowed to power down any particular power voltage rail, than this means this voltage rail must be powered even if this functionality is not used.
