PTP on LX2160A
PTP on LX2160A
2,725 次查看
hawx
I read that LX2160A has support for PTP.
Does it mean that the configuration and PTP clock synchronization happens at the board/firmware level and is transparent to the OS?
2,713 次查看
yipingwang
lx2160A supports PTP means PTP is supported in hardware, there are PTP related drivers in LSDK and it is supported by linuxptp protocol software.
2,709 次查看
hawx
Hi Yiping, thanks for your answer. Sorry I do not fully understand the second part. If I am using a RTOS, does it mean that the PTP clock synchronization logic still has to be implemented at the driver layer, even though the hardware supports PTP? What does the hardware actually do to support PTP?
2,676 次查看
yipingwang
Driver layer support is needed.
