CLOCK GENERATOR FOR LS1046
Ellu24
1) I want to design a new hardware using LS1046a.Please suggest me a clock generator for the same.
2) When I checked the design files the clock used is 6V49205BNLGI ,which is not in stock for most of the providers. Can you please suggest another alternatives for this which is easily available and provide supplier link if possible .
yipingwang
Customer can use any clock source which is comply with the specification mentioned in datasheet.
NXP doesn't recommend any part.
