MC error: Unsupported operation (status 0xb)
1,529 次查看
yuanqh
when I use  ls-addni to add netconect, MC error: Unsupported operation (status 0xb),why?
1,462 次查看
yipingwang
Hello yuan qinghua,
This is because restool provided in the rootfs file system is incompatible with MC firmware version?
Please use rootfs filesystem  and MC firmware from the same LSDK?
Which version LSDK do you use? Do you use LS2088ARDB?
Yiping
