LSDK21.08 LS1043AQDS SETUP
SpringMelon
Hello, Wang. With your help, my board ls1043aqds has entered uboot. I use LSDK 21.08 for development, and the boot mode is TF-A. But my qspi flash is small, only 16MB, so I can't write itb directly to flash and start kernel and ramdisk from qspi.
I think the next priority is to burn the kernel and ramdisk into 16GB emmc, and then load the kernel from emmc. But I don't know if I have to use an external writer to burn emmc at the moment, and I don't know exactly what needs to be modified and compiled in the next work.
I really hope to get your help and look forward to your reply as soon as possible. thank you.
@yipingwang
yipingwang
You need to modify LS1043AQDS device tree according to your custom board.
In LSDK 21.08 build environment:
$ source setup.env
$ flex-builder -c linux -m ls1043aqds
Go to Linux Kernel source code components/linux/linux, please modify arch/arm64/boot/dts/freescale/fsl-ls1043a-qds.dts according to your custom board.
For example, please delete the following device node, if there is no IFC NOR flash on your custom board.
nor@0,0 {
compatible = "cfi-flash";
reg = <0x0 0x0 0x8000000>;
big-endian;
bank-width = <2>;
device-width = <1>;
Then rebuild Linux Kernel
Regenerate itb image
$ flex-builder -i mkitb -r yocto:tiny
Get the image flexbuild_lsdk2108_github/build/images/lsdk2108_yocto_tiny_LS_arm64.itb
If you need to the bootpartition image, please regenerate it with the following command
$ flex-builder -i mkbootpartition -a arm64
yipingwang
The emmc device is not removable, you could copy all your images to the USB device, then boot up the target board with image lsdk2108_yocto_tiny_LS_arm64.itb and deploy Ubuntu rootfs to emmc device in Linux on the target board.
For example under u-boot,
=> ext2load usb 0:1 0xa0000000 lsdk2108_yocto_tiny_LS_arm64.itb
=> bootm 0xa0000000#ls1043aqds
Under Linux on the target board, please run the following commands to deploy Kernel and Ubuntu rootfs to emmc device.
$ flex-installer -i pf -d /dev/mmcblk0
$ flex-installer -b boot_LS_arm64_lts_5.10.tgz -r rootfs_lsdk2108_ubuntu_main_arm64.tgz -d /dev/mmcblk0
Note:/dev/mmcblk0 is the emmc device name on the target board.
SpringMelon
Wang,Thank you very much for your technical reply, and I am honored to get your help in debugging this series of boards for the first time. I have made some progress following your suggestions, but it seems that the kernel is stuck and cannot continue. I have attached the log, and I hope to get your help on what I should do next so that I can successfully enter ramdisk.
@yipingwang
yipingwang
$ source setup.env
nor@0,0 {
big-endian;
bank-width = <2>;
device-width = <1>;
SpringMelon
Dear WANG,Thank you very much for your help, I can now enter the official ubuntu file system.
%3CLINGO-SUB%20id%3D%22lingo-sub-1906887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELSDK21.08%20LS1043AQDS%20SETUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20Wang.%20With%20your%20help%2C%20my%20board%20ls1043aqds%20has%20entered%20uboot.%20I%20use%20LSDK%2021.08%20for%20development%2C%20and%20the%20boot%20mode%20is%20TF-A.%20But%20my%20qspi%20flash%20is%20small%2C%20only%2016MB%2C%20so%20I%20can't%20write%20itb%20directly%20to%20flash%20and%20start%20kernel%20and%20ramdisk%20from%20qspi.%3C%2FP%3E%3CP%3EI%20think%20the%20next%20priority%20is%20to%20burn%20the%20kernel%20and%20ramdisk%20into%2016GB%20emmc%2C%20and%20then%20load%20the%20kernel%20from%20emmc.%20But%20I%20don't%20know%20if%20I%20have%20to%20use%20an%20external%20writer%20to%20burn%20emmc%20at%20the%20moment%2C%20and%20I%20don't%20know%20exactly%20what%20needs%20to%20be%20modified%20and%20compiled%20in%20the%20next%20work.%3C%2FP%3E%3CP%3EI%20really%20hope%20to%20get%20your%20help%20and%20look%20forward%20to%20your%20reply%20as%20soon%20as%20possible.%20thank%20you.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LSDK21.08%20LS1043AQDS%20SETUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDear%20WANG%2CThank%20you%20very%20much%20for%20your%20help%2C%20I%20can%20now%20enter%20the%20official%20ubuntu%20file%20system.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LSDK21.08%20LS1043AQDS%20SETUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20need%20to%20modify%20LS1043AQDS%20device%20tree%20according%20to%20your%20custom%20board.%3C%2FP%3E%0A%3CP%3EIn%20LSDK%2021.08%20build%20environment%3A%3C%2FP%3E%0A%3CP%3E%24%20source%20setup.env%3C%2FP%3E%0A%3CP%3E%24%20flex-builder%20-c%20linux%20-m%20ls1043aqds%3C%2FP%3E%0A%3CP%3EGo%20to%20Linux%20Kernel%20source%20code%26nbsp%3Bcomponents%2Flinux%2Flinux%2C%20please%20modify%26nbsp%3Barch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-qds.dts%20according%20to%20your%20custom%20board.%3C%2FP%3E%0A%3CP%3EFor%20example%2C%20please%20delete%20the%20following%20device%20node%2C%20if%20there%20is%20no%20IFC%20NOR%20flash%20on%20your%20custom%20board.%3C%2FP%3E%0A%3CP%3Enor%400%2C0%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22cfi-flash%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x0%200x0%200x8000000%26gt%3B%3B%3CBR%20%2F%3Ebig-endian%3B%3CBR%20%2F%3Ebank-width%20%3D%20%26lt%3B2%26gt%3B%3B%3CBR%20%2F%3Edevice-width%20%3D%20%26lt%3B1%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThen%20rebuild%20Linux%20Kernel%3C%2FP%3E%0A%3CP%3E%24%20flex-builder%20-c%20linux%20-m%20ls1043aqds%3C%2FP%3E%0A%3CP%3ERegenerate%20itb%20image%3C%2FP%3E%0A%3CP%3E%24%20flex-builder%20-i%20mkitb%20-r%20yocto%3Atiny%3C%2FP%3E%0A%3CP%3EGet%20the%20image%20flexbuild_lsdk2108_github%2Fbuild%2Fimages%2Flsdk2108_yocto_tiny_LS_arm64.itb%3C%2FP%3E%0A%3CP%3EIf%20you%20need%20to%20the%20bootpartition%20image%2C%20please%20regenerate%20it%20with%20the%20following%20command%3C%2FP%3E%0A%3CP%3E%24%20flex-builder%20-i%20mkbootpartition%20-a%20arm64%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910259%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LSDK21.08%20LS1043AQDS%20SETUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910259%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWang%2CThank%20you%20very%20much%20for%20your%20technical%20reply%2C%20and%20I%20am%20honored%20to%20get%20your%20help%20in%20debugging%20this%20series%20of%20boards%20for%20the%20first%20time.%20I%20have%20made%20some%20progress%20following%20your%20suggestions%2C%20but%20it%20seems%20that%20the%20kernel%20is%20stuck%20and%20cannot%20continue.%20I%20have%20attached%20the%20log%2C%20and%20I%20hope%20to%20get%20your%20help%20on%20what%20I%20should%20do%20next%20so%20that%20I%20can%20successfully%20enter%20ramdisk.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1908502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LSDK21.08%20LS1043AQDS%20SETUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1908502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20emmc%20device%20is%20not%20removable%2C%20you%20could%20copy%20all%20your%20images%20to%20the%20USB%20device%2C%20then%20boot%20up%20the%20target%20board%20with%20image%20lsdk2108_yocto_tiny_LS_arm64.itb%20and%20deploy%20Ubuntu%20rootfs%20to%20emmc%20device%20in%20Linux%20on%20the%20target%20board.%3C%2FP%3E%0A%3CP%3EFor%20example%20under%20u-boot%2C%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20ext2load%20usb%200%3A1%200xa0000000%20lsdk2108_yocto_tiny_LS_arm64.itb%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20bootm%26nbsp%3B0xa0000000%23ls1043aqds%3C%2FP%3E%0A%3CP%3EUnder%20Linux%20on%20the%20target%20board%2C%20please%20run%20the%20following%20commands%20to%20deploy%20Kernel%20and%20Ubuntu%20rootfs%20to%20emmc%20device.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%24%20flex-installer%20-i%20pf%20-d%20%2Fdev%2Fmmcblk0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%24%20flex-installer%20-b%20boot_LS_arm64_lts_5.10.tgz%20-r%20rootfs_lsdk2108_ubuntu_main_arm64.tgz%20-d%20%2Fdev%2Fmmcblk0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ENote%3A%2Fdev%2Fmmcblk0%20is%20the%20emmc%20device%20name%20on%20the%20target%20board.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
