- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hello, Wang. With your help, my board ls1043aqds has entered uboot. I use LSDK 21.08 for development, and the boot mode is TF-A. But my qspi flash is small, only 16MB, so I can't write itb directly to flash and start kernel and ramdisk from qspi.
I think the next priority is to burn the kernel and ramdisk into 16GB emmc, and then load the kernel from emmc. But I don't know if I have to use an external writer to burn emmc at the moment, and I don't know exactly what needs to be modified and compiled in the next work.
I really hope to get your help and look forward to your reply as soon as possible. thank you.
Solved! Go to Solution.
![NXP TechSupport NXP TechSupport](/html/@31A3486DB369D9771A481951B44308DB/assets/favicon-3.16x16.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You need to modify LS1043AQDS device tree according to your custom board.
In LSDK 21.08 build environment:
$ source setup.env
$ flex-builder -c linux -m ls1043aqds
Go to Linux Kernel source code components/linux/linux, please modify arch/arm64/boot/dts/freescale/fsl-ls1043a-qds.dts according to your custom board.
For example, please delete the following device node, if there is no IFC NOR flash on your custom board.
nor@0,0 {
compatible = "cfi-flash";
reg = <0x0 0x0 0x8000000>;
big-endian;
bank-width = <2>;
device-width = <1>;
Then rebuild Linux Kernel
Regenerate itb image
$ flex-builder -i mkitb -r yocto:tiny
Get the image flexbuild_lsdk2108_github/build/images/lsdk2108_yocto_tiny_LS_arm64.itb
If you need to the bootpartition image, please regenerate it with the following command
$ flex-builder -i mkbootpartition -a arm64
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The emmc device is not removable, you could copy all your images to the USB device, then boot up the target board with image lsdk2108_yocto_tiny_LS_arm64.itb and deploy Ubuntu rootfs to emmc device in Linux on the target board.
For example under u-boot,
=> ext2load usb 0:1 0xa0000000 lsdk2108_yocto_tiny_LS_arm64.itb
=> bootm 0xa0000000#ls1043aqds
Under Linux on the target board, please run the following commands to deploy Kernel and Ubuntu rootfs to emmc device.
$ flex-installer -i pf -d /dev/mmcblk0
$ flex-installer -b boot_LS_arm64_lts_5.10.tgz -r rootfs_lsdk2108_ubuntu_main_arm64.tgz -d /dev/mmcblk0
Note:/dev/mmcblk0 is the emmc device name on the target board.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Wang,Thank you very much for your technical reply, and I am honored to get your help in debugging this series of boards for the first time. I have made some progress following your suggestions, but it seems that the kernel is stuck and cannot continue. I have attached the log, and I hope to get your help on what I should do next so that I can successfully enter ramdisk.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
$ source setup.env
nor@0,0 {
big-endian;
bank-width = <2>;
device-width = <1>;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
![](/skins/images/2751E9A630235A938C9EEE682B5D7B7C/responsive_peak/images/icon_anonymous_message.png)
