LS1046A - IFC GPCM Support for CSOR[ADM_SHFT_MODE] =1
2,682 次查看
CGganesh
Our design is to support 20-bit addressing of IFC in GPCM mode. GPCM Mode of IFC will it support both CSOR[ADM_SHFT_MODE] 0 & 1 ?
Ganesh
1 回复
2,644 次查看
Hector_Villarruel
Hello, Thank you for contacting the Technical Support Team,
Yes, it is possible if you write on the register ADM_SHFT “10100” you will have IFC with 20 bit Address,
On the other hand writing on the register ADM_SHFT_ MODE “0” or “1”you will be able to you can switch to less significant and more significant directions.
I attach some referenced images obtained from the reference manual.
Hector Villarruel S
