LS1043A does not support MII ?
1,718 次查看
stefanvranken
Am desiging with LS1043A.
For other designs (older cpu) we used an external box containing an ethernet port (RJ45 + 100M-phy). With a cable we connected MII (4bit rxd + 4bit tx-data, 25Mhz clock) to cpu.  Doing so, software-team could access the board easily without putting an extra 100M phy on the PCB.
But LS1043A does not support 100Mbit MII ?  LS1043A supports only1Gbps RGMII ?
Stefan
标签 (2)
标记 (1)
1,638 次查看
ufedor
Both answers are "Yes".
