LS1043A does not support MII ?
1,699件の閲覧回数
stefanvranken
Am desiging with LS1043A.
For other designs (older cpu) we used an external box containing an ethernet port (RJ45 + 100M-phy). With a cable we connected MII (4bit rxd + 4bit tx-data, 25Mhz clock) to cpu.  Doing so, software-team could access the board easily without putting an extra 100M phy on the PCB.
But LS1043A does not support 100Mbit MII ?  LS1043A supports only1Gbps RGMII ?
Stefan
ラベル(2)
タグ(1)
1,619件の閲覧回数
ufedor
Both answers are "Yes".
