LS1043A MUX SIGNAL SELECTION
1,898 次查看
logeshs
We are using LS1043A in our Design.
1. We have listed down all the signals of the processor as per our design implementation. Kindly Check the List of pins i have attached in the attachment and confirm whether we can proceed with the current MUX signals selection.
2. We do not have any GUI for this processor to select the MUX signals. Kindly request you to share if you have any.
标记 (1)
1,678 次查看
Pavel
It looks like that your pin muxing is correct.
We recommend check your pin muxing using schematic of the LS1043ARDB:
https://www.nxp.com/webapp/Download?colCode=LS1043A-RDB_DESIGN_FILES&appType=license&Parent_nodeId=1...
Pavel Chubakov
1,678 次查看
logeshs
I kindly request you to share GUI for Mux Pin selection in LS1043A. So that we shall cross verify whenever needed.
1,678 次查看
logeshs
Please acknowledge if you have received any attachment. I'm not able to upload the attachment in Excel, then i tried with Word.
