LS1012A - How to enable Packet Forwarding Engine(PFE)
Bao141
Hello NXP guys,
I am using ubuntu18.04 on my board(with ls1012a),I want enable PFE,I downloaded a lot of files about 1012 but couldn’t find the manual on how to enable pfe
I hope you can help me,thank you for reading.
bpe
  • Only one kernel configuration option is required to enable PPFE support in the
    kernel, namely CONFIG_FSL_PPFE.
  • Stay with LSDK kernel
  • Build your firmware with NXP LSDK for the appropriate target. This ensures PPFE firmware binary is included in the image.
  • Stop PPFE in u-Boot before bootm:
pfe stop; bootm
Hope this helps,
Platon
