IFC GPCM WE_B usage
IFC GPCM WE_B usage
1,405 次查看
benoitmasse
In Document Number: LS2088ARM Rev. 1, 09/2020.
In section 17.9 General purpose chip-select machine, in figures 17-46, 17-47, 17-48, 17-49 and 17-50, the WE_B is display as a four bits Bus. But our comprehension is that the WE_B signal is a single bit.
Can you explain why WE_B is display as a 4 bits signal ?
1,396 次查看
r8070z
These figures do not show WE_B as four bits bus signal. These figures are just sloppy. In the same way  table 17-1 has lost IFC_WE0_B at all.
