How do I modify an ITB source
ソリューションへジャンプ
1,698件の閲覧回数
muaxi8
Contributor V
i use command  "flex-builder -i mkitb -r yocto:tiny -a arm64" to build lsdk2012_yocto_tiny_LS_arm64.itb。
But it has a lot of device trees. Where can I modify it to remove the device tree configuration that I don't need ?
1,695件の閲覧回数
yipingwang
You could modify file configs/linux/linux_arm64_LS.its in LSDK according to your requirement.
1,696件の閲覧回数
yipingwang
