Generating customised rootfs for my customizes application
1,294件の閲覧回数
dibyarekha
Hi All,
I am using LS1043ardb, I am able to compile all packages I need with merge-files and able to generate rootfs by using bitbake fsl-image-mfgtool.
I want to generate the rootfs with the user application by merging all packages and  the generated rootfs should run in the board with all packages and merge-files.
How can I do that?
Please help me
タグ(1)
1,233件の閲覧回数
khushbur
Hi @dibyarekha
To add a file in rootfs:
- copy files to recipes-extended/merge-files/merge-files/files/merge/
-make sure package 'merge-files' in the IMAGE_INSTALL list of rootfs recipe
タグ(1)
2 返答(返信)
1,234件の閲覧回数
khushbur
Hi @dibyarekha
タグ(1)
1,181件の閲覧回数
dibyarekha
Thank you
