Compilation Error LSDK
1,780件の閲覧回数
deepanrajanbara
I tried compiling the LSDK in my ubuntu 18.04 PC. But am not able to compile successfully for LX2160A chipset.
Below are the commands given by me.
flex-builder -m lx2160ardb
The error which i get is
 Building weston ...
Cloning into 'weston'...
warning: redirecting to https://source.codeaurora.org/external/imx/weston-imx.git/
warning: remote HEAD refers to nonexistent ref, unable to checkout.
Switched to a new branch 'rel_virt_4.14.98_4.11_0.10_ga'
~/flexbuild_lsdk1909_update_221019/packages/apps
chroot: failed to run command ‘ldconfig’: Exec format error
Makefile:720: recipe for target 'weston' failed
make[1]: *** [weston] Error 126
make[1]: Leaving directory '~/flexbuild_lsdk1909_update_221019/packages/apps'
Makefile:28: recipe for target 'apps' failed
make: *** [apps] Error 2
make: Leaving directory '~/flexbuild_lsdk1909_update_221019'
ラベル(2)
1,694件の閲覧回数
Pavel
Try to install “sudo apt install -y binfmt-support qemu-system-common qemu-user-static“.
It should resolve your issue.
Pavel Chubakov
