OPC UA PubSub on OpenIL
2,317 次查看
florian_fouille
Hi everyone,
I'm planning on using the LS1028ARDB Dev-board with OpenIL.
I saw that the OpenIL Rev 1.7 use the OPC UA stack open62541 (Version 0.2).
However the Open62541 version 0.2 doesn't support PubSub (only Client/Server).
what would be the easiest way to port the new version of Open62541 (Version 1.0) into the OpenIL distri?
Thank you for your help.
2 回复数
2,239 次查看
alexander_yakov
Sorry for delayed response to this.
Factory engineering team replied they are already in direct communication with you regarding libopen62541 v1.0
I expect the support for libopen62541 v1.0 will be included in the next release of OpenIL
2,239 次查看
florian_fouille
Indeed we heard back from support.
