CodeWarrior® TAP without CodeWarrior software?
3,169件の閲覧回数
miha_at_work
Hello.
Is there some way to use CodeWarrior TAP for debugging device based on LS2084 using only open source or low cost software. CodeWarrior is very expensive for us.
6 返答(返信)
3,019件の閲覧回数
miha_at_work
So how about GDB?
3,019件の閲覧回数
ufedor
CodeWarrior TAP supports network port 2345 used by GDB to control the TAP.
3,019件の閲覧回数
miha_at_work
Is TAP compatible with GDB? Will it stable work with GDB?
3,019件の閲覧回数
ufedor
The GDB is not an NXP product and it is not officially supported.
Please use NXP Community to find additional information.
3,019件の閲覧回数
miha_at_work
Ok. Thank you.
3,019件の閲覧回数
ufedor
Please check tools from other vendors: Lauterbach, Wind River, Green Hills.
