LS1043ARDB - How to update DPAA1 FMan microcode (ucode) image on SD card
Follow these steps to update the DPAA1 FMan ucode image on the SD card.
Obtaining DPAA1 FMan ucode image
Clone the qoriq-fm-ucode repository.
  1. git clone https://github.com/NXP/qoriq-fm-ucode.git
  2. $ cd qoriq-fm-ucode
  3. $ git checkout LSDK-<LSDK version>For example, $ git checkout LSDK-19.06
The prebuilt FMan ucode images, fsl_fman_ucode_ls1043_r1.1_<microcode version>.bin, are at qoriq-fm-ucode/. In the binary file, ls1043_r1.1 refers to the LS1043A silicon revision 1.1. See qoriq-fm-ucode/readme for a description of the ucode version numbers.
SD card start block number for DPAA1 FMan ucode image
Image  SD card start block number
0x04800 = 18432
Refer Flash layout for new boot flow with TF-A for complete listing of the SD card start block numbers for all LSDK firmware images.
Programming DPAA1 FMan ucode image to SD card
Option 1: Load image on SD card plugged into Linux host via dd command
  1. Plug the SD card into the Linux host.
  2. Run the following command on the Linux host:
    • $ sudo dd if=fsl_fman_ucode_ls1043_r1.1_<ucode version>.bin of=/dev/sdX bs=512 seek=18432 conv=fsync
      Use the command cat /proc/partitions to see a list of devices and their sizes to make sure that the correct device names have been chosen.
      The SDHC storage drive in the Linux PC is detected as /dev/sdX, where X is a letter such as a, b, c. Make sure to choose the correct device name, because data on this device will be replaced.
      If your Linux host machine supports read/write SDHC card directly without an extra SDHC card reader device, the device name of SDHC card is typically mmcblk0.
  3. Remove the SD card from the Linux host machine.
  4. Plug the SD card into LS1043ARDB and boot the board to Ubuntu using the SD card. You can boot the board using the SD card either by:
    • setting the switches: SW3[1:8] = 10110011, SW4 [1:8] =00100000SW5 [1:8] = 00100010, or
    • boot switching to SD card => cpld reset sd
In boot log, you’ll see:
Board: LS1043ARDB, boot from SD
You can check the following code line in the boot log to confirm that the DPAA1 FMan ucode image on the SD card is updated.
Fman1: Uploading microcode version 106.4.18
If U-Boot does not find LSDK on the SD card, it will boot TinyDistro from lsdk_linux_arm64_tiny.itb stored on the SD card.
Option 2: Load image on SD card plugged into board from the TFTP server
  1. Boot LS1043ARDB from NOR flash. Ensure that the switches are set to boot the board from NOR bank 0. For booting from NOR bank 0, switch settings are as follows:
    • SW3[1:8] = 10110011
    • SW4[1:8] = 00010010
    • SW5[1:8] = 10100010
  2. Boot from NOR bank 0: => cpld reset
    For LS1043ARDB, in boot log, you'll see:
    Board: LS1043ARDB, boot from vBank 0
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
FM1@DTSEC1, FM1@DTSEC2, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5
  1. Set server IP address to the IP address of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the Ethernet interface connected to the TFTP server.
    See LS1043ARDB Ethernet and FMC port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime FM1@DTSEC4
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact FM1@DTSEC4
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings. => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using FM1@DTSEC4 device
host 192.168.1.1 is alive
Load FMan ucode image from the TFTP server
  1. Flash the FMan ucode image=> tftp 0xa0000000 fsl_fman_ucode_ls1043_r1.1_<ucode version>.bin
  2. Program the FMan ucode image to SD card: => mmc write 0xa0000000 0x04800 <blk_cnt>
    Address  0x04800 is the SD card block number for the FMan ucode image.  ReferFlash layout for new boot flow with TF-A for the complete flash memory layout.
    Here, blk_cnt refers to number of blocks in SD card that need to be written as per the file size.
    For example, when you load FMan ucode from the TFTP server, if the bytes transferred is 37560 (92b8 hex), then blk_cnt is calculated as "37560/512 = 73 (49 hex)" + "few sectors for rounding up so that last block is not missed". So, if you round up by 5 (5 hex) sectors, for this example, mmc write command will be: => mmc write 0xa0000000 0x04800 4E
  3. You can boot the board using the SD card either by:
    • setting the switches: SW3[1:8] = 10110011, SW4 [1:8] =00100000 SW5 [1:8] = 00100010, or
评论
I think it will be good to have also a section where you show how we write the sd card from u-boot in case we do not have a card reader on the host
%3CLINGO-SUB%20id%3D%22lingo-sub-1118020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1043ARDB%20-%20%E5%A6%82%E4%BD%95%E5%9C%A8SD%E5%8D%A1%E4%B8%8A%E6%9B%B4%E6%96%B0DPAA1%20FMan%E5%BE%AE%E4%BB%A3%E7%A0%81%20(ucode)%20%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%9B%B4%E6%96%B0SD%E5%8D%A1%E4%B8%8A%E7%9A%84DPAA1%20FMan%20ucode%E9%95%9C%E5%83%8F%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId-381646886%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId-381646886%22%20id%3D%22toc-hId-1303118080%22%3E%E8%8E%B7%E5%8F%96DPAA1%20FMan%20ucode%E5%9B%BE%E5%83%8F%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%85%8B%E9%9A%86%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqoriq-fm-ucode%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BB%A3%E7%A0%81%E5%BA%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%26nbsp%3B%3CA%20style%3D%22color%3A%20%23606060%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fqoriq-fm-ucode.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%24%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20qoriq-fm-ucode%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Egit%20checkout%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3ELSDK-%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FSPAN%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Egit%20checkout%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3ELSDK-19.06%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%20%3C%2FOL%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E9%A2%84%E6%9E%84%E5%BB%BA%E7%9A%84%20FMan%20ucode%20%E6%98%A0%E5%83%8F%EF%BC%8C%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efsl_fman_ucode_ls1043_r1.1%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E_%3CMICROCODE%20version%3D%22%22%3E.bin%3C%2FMICROCODE%3E%3C%2FSPAN%3E%EF%BC%8C%E4%BD%8D%E4%BA%8E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqoriq-fm-ucode%2F%3C%2FSPAN%3E%E3%80%82%E5%9C%A8%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els1043_r1.1%3C%2FSPAN%3E%20%E6%8C%87%E7%9A%84%E6%98%AF%20LS1043A%20%E8%8A%AF%E7%89%87%E7%89%88%E6%9C%AC%201.1%E3%80%82%E6%9C%89%E5%85%B3%20ucode%20%E7%89%88%E6%9C%AC%E5%8F%B7%E7%9A%84%E6%8F%8F%E8%BF%B0%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqoriq-fm-ucode%2Freadme%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId--1425807577%22%20id%3D%22toc-hId--1425807577%22%20id%3D%22toc-hId--504336383%22%3EDPAA1%20FMan%20%E5%BE%AE%E7%A0%81%E9%95%9C%E5%83%8F%E7%9A%84%20SD%20%E5%8D%A1%E8%B5%B7%E5%A7%8B%E5%9D%97%E5%8F%B7%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%3E%20%3CTHEAD%3E%20%3CTR%3E%20%3CTH%3E%E5%9B%BE%E5%83%8F%3C%2FTH%3E%20%3CTH%3ESD%E5%8D%A1%E8%B5%B7%E5%A7%8B%E5%9D%97%E5%8F%B7%3C%2FTH%3E%20%3C%2FTR%3E%20%3C%2FTHEAD%3E%20%3CTBODY%3E%20%3CTR%3E%20%3CTD%3E%20%3CP%3EDPAA1%20FMan%20ucode%E5%9B%BE%E5%83%8F%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%3E0x04800%20%3D%2018432%3C%2FTD%3E%20%3C%2FTR%3E%20%3C%2FTBODY%3E%20%3C%2FTABLE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%0A%E8%AF%B7%E5%8F%82%E9%98%85%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20target%3D%22_blank%22%3E%E6%94%AF%E6%8C%81%20TF-A%20%E7%9A%84%E6%96%B0%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%20Flash%20%E5%B8%83%E5%B1%80%3C%2FA%3E%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%8F%96%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%E6%89%80%E6%9C%89%20LSDK%20%E5%9B%BA%E4%BB%B6%E6%98%A0%E5%83%8F%E7%9A%84%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E5%9D%97%E7%BC%96%E5%8F%B7%E7%9A%84%E5%AE%8C%E6%95%B4%E5%88%97%E8%A1%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FPRE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH1%20id%3D%22toc-hId-1061705256%22%20id%3D%22toc-hId-1061705256%22%20id%3D%22toc-hId-1983176450%22%3E%E5%B0%86%20DPAA1%20FMan%20%E5%BE%AE%E7%A0%81%E9%95%9C%E5%83%8F%E7%BC%96%E7%A8%8B%E8%87%B3%20SD%20%E5%8D%A1%3C%2FH1%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId-1752266730%22%20id%3D%22toc-hId-1752266730%22%20id%3D%22toc-hId--1621229372%22%3E%E9%80%89%E9%A1%B9%E4%B8%80%EF%BC%9A%E9%80%9A%E8%BF%87%20dd%20%E5%91%BD%E4%BB%A4%E5%B0%86%E6%98%A0%E5%83%8F%E5%8A%A0%E8%BD%BD%E5%88%B0%E6%8F%92%E5%85%A5%20Linux%20%E4%B8%BB%E6%9C%BA%E7%9A%84%20SD%20%E5%8D%A1%E4%B8%8A%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3COL%3E%20%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20Linux%20%E4%B8%BB%E6%9C%BA%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%3E%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%20%20%20%20%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%20%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%26nbsp%3Bsudo%20dd%20if%3D%3CSPAN%3Efsl_fman_ucode_ls1043_r1.1_%3CUCODE%3E.bin%3C%2FUCODE%3E%3C%2FSPAN%3E%26nbsp%3Bof%3D%2Fdev%2FsdX%20bs%3D512%20seek%3D18432%20conv%3Dfsync%3C%2FSPAN%3E%20%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E6%89%A7%E8%A1%8C%20cat%20%2Fproc%2Fpartitions%20%E5%91%BD%E4%BB%A4%E6%9F%A5%E7%9C%8B%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%E5%8F%8A%E5%85%B6%E5%AE%B9%E9%87%8F%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%89%80%E9%80%89%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELinux%20%E7%94%B5%E8%84%91%E4%B8%AD%E7%9A%84%20SDHC%20%E5%AD%98%E5%82%A8%E9%A9%B1%E5%8A%A8%E5%99%A8%E8%A2%AB%E6%A3%80%E6%B5%8B%E4%B8%BA%20%2Fdev%2FsdX%EF%BC%8C%E5%85%B6%E4%B8%AD%20X%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AD%97%E6%AF%8D%EF%BC%8C%E5%A6%82%20a%E3%80%81b%E3%80%81c%E3%80%82%E8%AF%B7%E5%8A%A1%E5%BF%85%E9%80%89%E6%8B%A9%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%AD%A4%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E6%95%B0%E6%8D%AE%E5%B0%86%E8%A2%AB%E6%9B%BF%E6%8D%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%20Linux%20%E4%B8%BB%E6%9C%BA%E6%94%AF%E6%8C%81%E7%9B%B4%E6%8E%A5%E8%AF%BB%E5%86%99%20SDHC%20%E5%8D%A1%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E9%A2%9D%E5%A4%96%E7%9A%84%20SDHC%20%E5%8D%A1%E8%AF%BB%E5%8D%A1%E5%99%A8%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%88%99%20SDHC%20%E5%8D%A1%E7%9A%84%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%E9%80%9A%E5%B8%B8%E4%B8%BA%20mmcblk0%E3%80%82%3C%2FP%3E%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3C%2FPRE%3E%20%3C%2FLI%3E%20%3C%2FUL%3E%20%3C%2FLI%3E%20%3CLI%3E%E4%BB%8E%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%A7%BB%E9%99%A4%20SD%20%E5%8D%A1%E3%80%82%3C%2FLI%3E%20%3CLI%3E%E5%B0%86%20SD%20%E5%8D%A1%E6%8F%92%E5%85%A5%20LS1043ARDB%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20SD%20%E5%8D%A1%E5%B0%86%E5%BC%80%E5%8F%91%E6%9D%BF%E5%BC%95%E5%AF%BC%E8%BF%9B%E5%85%A5%20Ubuntu%20%E7%B3%BB%E7%BB%9F%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%EF%BC%9A%20%3CUL%3E%20%3CLI%3E%E8%AE%BE%E7%BD%AE%E5%BC%80%E5%85%B3%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW3%5B1%3A8%5D%20%3D%2010110011%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%EF%BC%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW4%20%5B1%3A8%5D%20%3D%2000100000%3C%2FSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%20%5B1%3A8%5D%20%3D%2000100010%3C%2FSPAN%3E%EF%BC%8C%E6%88%96%3C%2FLI%3E%20%3CLI%3E%E5%90%AF%E5%8A%A8%E5%88%87%E6%8D%A2%E5%88%B0%20SD%20%E5%8D%A1%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20CPLD%20%E9%87%8D%E7%BD%AE%20SD%3C%2FSPAN%3E%3C%2FLI%3E%20%3C%2FUL%3E%20%3C%2FLI%3E%20%3C%2FOL%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1043ARDB%EF%BC%8C%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E5%8F%AF%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E8%A1%8C%EF%BC%8C%E7%A1%AE%E8%AE%A4%20SD%20%E5%8D%A1%E4%B8%8A%E7%9A%84%20DPAA1%20FMan%20%E5%BE%AE%E7%A0%81%E9%95%9C%E5%83%8F%E5%B7%B2%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFman1%EF%BC%9A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%E5%BE%AE%E4%BB%A3%E7%A0%81%E7%89%88%E6%9C%AC%20106.4.18%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E5%A6%82%E6%9E%9C%20U-Boot%20%E5%9C%A8%20SD%20%E5%8D%A1%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%20LSDK%EF%BC%8C%E5%AE%83%E5%B0%86%E4%BB%8E%20SD%20%E5%8D%A1%E4%B8%8A%E5%AD%98%E5%82%A8%E7%9A%84%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E6%96%87%E4%BB%B6%E4%B8%AD%E5%90%AF%E5%8A%A8%20TinyDistro%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH2%20id%3D%22toc-hId--55187733%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--55187733%22%20id%3D%22toc-hId-866283461%22%3E%E9%80%89%E9%A1%B9%E4%BA%8C%EF%BC%9A%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BD%E5%88%B0%E6%8F%92%E5%85%A5%E4%B8%BB%E6%9D%BF%E7%9A%84%20SD%20%E5%8D%A1%E4%B8%8A%E7%9A%84%E6%98%A0%E5%83%8F%3C%2FH2%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E4%BB%8E%20NOR%20%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%3CSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3ELS1043ARDB%3C%2FSPAN%3E%E3%80%82%E7%A1%AE%E4%BF%9D%E5%B0%86%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BB%8E%20NOR%20bank%200%20%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E8%A6%81%E4%BB%8E%20%3CSPAN%3ENOR%20bank%200%3C%2FSPAN%3E%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%20%3CUL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW3%5B1%3A8%5D%20%3D%2010110011%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW4%5B1%3A8%5D%20%3D%2000010010%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%2010100010%3C%2FSPAN%3E%3C%2FLI%3E%20%3C%2FUL%3E%20%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E4%BB%8E%3CSPAN%3E%26nbsp%3BNOR%26nbsp%3Bbank%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E0%26nbsp%3B%E5%90%AF%E5%8A%A8%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20cpld%20reset%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS1043ARDB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E4%BC%9A%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%20%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%9D%BF%EF%BC%9ALS1043ARDB%EF%BC%8C%E4%BB%8EvBank%200%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FLI%3E%20%3C%2FOL%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH3%20id%3D%22toc-hId-635373741%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-635373741%22%20id%3D%22toc-hId-1556844935%22%3E%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%3C%2FH3%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8CU-Boot%20%E4%BC%9A%E6%89%93%E5%8D%B0%E5%87%BA%E5%B7%B2%E5%90%AF%E7%94%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E5%88%97%E8%A1%A8%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFM1%40DTSEC1%2C%20FM1%40DTSEC2%2C%20FM1%40DTSEC3%20%5BPRIME%5D%2C%20FM1%40DTSEC4%2C%20FM1%40DTSEC5%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%B0%86%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%20%E5%9C%B0%E5%9D%80%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%82%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FSPAN%3E%20%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%20%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%B0%86%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethact%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethprime%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%20%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%3CSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22341964%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-343516%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%20LS1043ARDB%20Ethernet%20%E5%92%8C%20FMC%20%E7%AB%AF%E5%8F%A3%E6%98%A0%E5%B0%84%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%EF%BC%8C%E4%BA%86%E8%A7%A3%E6%9C%BA%E7%AE%B1%E5%89%8D%E9%9D%A2%E6%9D%BF%E4%B8%8A%E6%98%BE%E7%A4%BA%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E4%B8%8E%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EU-Boot%20%E5%92%8C%20Linux%20%E4%B8%AD%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E7%9A%84%E5%AF%B9%E5%BA%94%E5%85%B3%E7%B3%BB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FPRE%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%3E%3D%26gt%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethprime%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esetenv%20ethact%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E8%AE%BE%E7%BD%AE%E7%94%B5%E8%B7%AF%E6%9D%BF%E7%9A%84IP%E5%9C%B0%E5%9D%80%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81IP%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%88%96%E8%80%85%E5%A6%82%E6%9E%9C%E4%B8%BB%E6%9D%BF%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0DHCP%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Edhcp%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FSPAN%3E%20%3CP%20style%3D%22margin%3A%200px%3B%22%3E%E9%9D%99%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ipaddr%20%3CIPADDRESS2%3E%3C%2FIPADDRESS2%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20netmask%20%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22margin%3A%200px%3B%22%3E%E5%8A%A8%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E4%BF%9D%E5%AD%98%E8%AE%BE%E7%BD%AE%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Esaveenv%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E6%A3%80%E6%9F%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B9%8B%E9%97%B4%E7%9A%84%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FLI%3E%20%3C%2FOL%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ping%20%24serverip%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%BD%BF%E7%94%A8%20FM1%40DTSEC4%20%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9C%BA%20192.168.1.1%20%E6%98%AF%E6%B4%BB%E8%B7%83%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CH3%20id%3D%22toc-hId--1172080722%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--1172080722%22%20id%3D%22toc-hId--250609528%22%3E%E4%BB%8ETFTP%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BDFMan%20ucode%E9%95%9C%E5%83%8F%3C%2FH3%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E5%88%B7%E5%86%99%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EFMan%20ucode%20%E6%98%A0%E5%83%8F%3C%2FSPAN%3E%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20tftp%200xa0000000%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Efsl_fman_ucode_ls1043_r1.1_.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%B0%86%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EFMan%20ucode%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%98%A0%E5%83%8F%E5%86%99%E5%85%A5%20SD%20%E5%8D%A1%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Emmc%20write%200xa0000000%200x04800%3CBLK_CNT%3E%3C%2FBLK_CNT%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%200x04800%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3C%2FSPAN%3E%20%E6%98%AF%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20FMan%20ucode%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%20%E6%98%A0%E5%83%8F%E7%9A%84%20SD%20%E5%8D%A1%E5%9D%97%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22342651%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20style%3D%22color%3A%20%232989c5%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3E%E6%94%AF%E6%8C%81%20TF-A%20%E7%9A%84%E6%96%B0%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%20Flash%20%E5%B8%83%E5%B1%80%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%8F%96%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%AE%8C%E6%95%B4%E7%9A%84%E9%97%AA%E5%AD%98%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E6%AD%A4%E5%A4%84%EF%BC%8C%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eblk_cnt%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E6%8C%87%E7%9A%84%E6%98%AF%E6%A0%B9%E6%8D%AE%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%E9%9C%80%E8%A6%81%E5%9C%A8%20SD%20%E5%8D%A1%E4%B8%8A%E5%86%99%E5%85%A5%E7%9A%84%E5%9D%97%E6%95%B0%E9%87%8F%E3%80%82%3C%2FP%3E%20%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BD%93%E6%82%A8%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BD%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3EFMan%20ucode%20%3C%2FSPAN%3E%E6%97%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BC%A0%E8%BE%93%E7%9A%84%E5%AD%97%E8%8A%82%E6%95%B0%E4%B8%BA%2037560%EF%BC%8892b8%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%EF%BC%89%EF%BC%8C%E5%88%99%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eblk_cnt%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E8%AE%A1%E7%AE%97%E4%B8%BA%E2%80%9C37560%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CEM%3E%2F512%20%3D%2073%EF%BC%8849%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%EF%BC%89%E2%80%9D%20%2B%20%E2%80%9C%E4%B8%BA%E4%BA%86%E5%90%91%E4%B8%8A%E5%8F%96%E6%95%B4%E4%BB%A5%E7%A1%AE%E4%BF%9D%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E5%9D%97%E4%B8%8D%E8%A2%AB%E9%81%97%E6%BC%8F%EF%BC%8C%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%E5%87%A0%E4%B8%AA%E6%89%87%E5%8C%BA%E2%80%9D%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%80%82%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%90%91%E4%B8%8A%E5%8F%96%E6%95%B4%E5%B9%B6%E5%A2%9E%E5%8A%A0%205%20%E4%B8%AA%E6%89%87%E5%8C%BA%EF%BC%88%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E4%B8%BA%205%EF%BC%89%EF%BC%8C%E5%9C%A8%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8Cmmc%20write%20%E5%91%BD%E4%BB%A4%E5%B0%86%E4%B8%BA%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Emmc%20write%200xa0000000%200x04800%204E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FLI%3E%20%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E4%BD%BF%E7%94%A8%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%9A%3CBR%20%2F%3E%20%3CUL%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%20%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E8%AE%BE%E7%BD%AE%E5%BC%80%E5%85%B3%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW3%5B1%3A8%5D%20%3D%2010110011%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%EF%BC%8C%3CSPAN%3E%20%3C%2FSPAN%3ESW4%20%5B1%3A8%5D%20%3D%2000100000%3CSPAN%3E%20%3C%2FSPAN%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%20%5B1%3A8%5D%20%3D%2000100010%3C%2FSPAN%3E%EF%BC%8C%E6%88%96%3C%2FLI%3E%20%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3E%E5%90%AF%E5%8A%A8%E5%88%87%E6%8D%A2%E5%88%B0%20SD%20%E5%8D%A1%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20CPLD%20%E9%87%8D%E7%BD%AE%20SD%3C%2FSPAN%3E%3C%2FLI%3E%20%3C%2FUL%3E%20%3C%2FLI%3E%20%3C%2FOL%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS1043ARDB%EF%BC%8C%E4%BB%8E%20SD%20%E5%8D%A1%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E5%8F%AF%E9%80%9A%E8%BF%87%E6%A3%80%E6%9F%A5%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E8%A1%8C%EF%BC%8C%E7%A1%AE%E8%AE%A4%20SD%20%E5%8D%A1%E4%B8%8A%E7%9A%84%20DPAA1%20FMan%20%E5%BE%AE%E7%A0%81%E9%95%9C%E5%83%8F%E5%B7%B2%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFman1%EF%BC%9A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%E5%BE%AE%E4%BB%A3%E7%A0%81%E7%89%88%E6%9C%AC%20106.4.18%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20margin%3A%200px%3B%20padding-left%3A%2030px%3B%22%3E%E5%A6%82%E6%9E%9C%20U-Boot%20%E5%9C%A8%20SD%20%E5%8D%A1%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%20LSDK%EF%BC%8C%3CSPAN%3E%3C%2FSPAN%3E%E5%AE%83%E5%B0%86%E4%BB%8E%20SD%20%E5%8D%A1%E4%B8%AD%E7%9A%84%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%3C%2FSPAN%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%20%E5%90%AF%E5%8A%A8%20TinyDistro%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118020%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E8%AE%BE%E5%A4%87%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%85%B3%E4%BA%8E%EF%BC%9ALS1043ARDB%20-%20%E5%A6%82%E4%BD%95%E5%9C%A8SD%E5%8D%A1%E4%B8%8A%E6%9B%B4%E6%96%B0DPAA1%20FMan%E5%BE%AE%E4%BB%A3%E7%A0%81%EF%BC%88ucode%EF%BC%89%E9%95%9C%E5%83%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%9C%80%E5%A5%BD%E8%BF%98%E8%83%BD%E5%A2%9E%E5%8A%A0%E4%B8%80%E4%B8%AA%E9%83%A8%E5%88%86%EF%BC%8C%E8%AF%B4%E6%98%8E%E5%9C%A8%E4%B8%BB%E6%9C%BA%E6%B2%A1%E6%9C%89%20SD%20%E5%8D%A1%E8%AF%BB%E5%8D%A1%E5%99%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%A6%82%E4%BD%95%E9%80%9A%E8%BF%87%20U-Boot%20%E5%90%91%20SD%20%E5%8D%A1%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:38 AM
更新人:
