Flash layout for new boot flow with TF-A
Please note that the LSDK memory layout for TF-A boot flow explained in this topic is only applicable for LSDK 18.12 and newer releases.
The following table shows the memory layout of various firmware stored in NOR/NAND/QSPI flash device or SD card on all QorIQ Reference Design Boards.
When the board boots from NOR flash, the NOR bank from which the board boots is considered as the "current bank" and the other bank is considered as the "alternate bank". For example, if LS1043ARDB boots from NOR bank 4, to update an image on NOR bank 0, you need to use the "alternate bank" address range,0x64000000 - 0x64F00000.
Firmware Definition MaxSize Flash Offset (QSPI/NAND flash) Absolute address (NOR bank 0 on LS1043ARDB, LS1021ATWR)
Absolute address
(NOR bank 4 LS1043ARDB, LS1021ATWR)
Absolute address (NOR bank 0 on LS2088ARDB)
Absolute address
(NOR bank 4 on LS2088ARDB)
SD Start Block No.
RCW + PBI + BL2 (bl2.pbl) 1 MiB 0x00000000 0x60000000 0x64000000 0x580000000
0x584000000
0x00008
ATF FIP Image (fip.bin) BL31 + BL32 + BL33 4 MiB 0x00100000 0x60100000 0x64100000 0x580100000 0x584100000 0x00800
Boot firmware environment 1 MiB 0x00500000 0x60500000 0x64500000 0x580500000 0x584500000 0x02800
Secure boot headers 2 MiB 0x00600000 0x60600000 0x64600000 0x580600000 0x584600000 0x03000
Secure header or DDR PHY FW 512 KiB 0x00800000 0x60800000 0x64800000 0x580800000 0x584800000 0x04000
Fuse provisioning header 512 KiB 0x00880000 0x60880000 0x64880000 0x580880000 0x584880000 0x04400
DPAA1 FMAN ucode 256 KiB 0x00900000 0x60900000 0x64900000 0x580900000 0x584900000 0x04800
QE/uQE firmware 256 KiB 0x00940000 0x60940000 0x64940000 0x580940000 0x584940000 0x04A00
Ethernet PHY firmware 256 KiB 0x00980000 0x60980000 0x64980000 0x580980000 0x584980000 0x04C00
Script for flashing image 256 KiB 0x009C0000 0x609C0000 0x649C0000 0x5809C0000 0x5849C0000 0x04E00
DPAA2-MC or PFE firmware 3 MiB 0x00A00000 0x60A00000 0x64A00000 0x580A00000 0x584A00000 0x05000
DPAA2 DPL 1 MiB 0x00D00000 0x60D00000 0x64D00000 0x580D00000 0x584D00000 0x06800
DPAA2 DPC 1 MiB 0x00E00000 0x60E00000 0x64E00000 0x580E00000 0x584E00000 0x07000
Device tree(needed by uefi) 1 MiB 0x00F00000 0x60F00000 0x64F00000 0x580F00000 0x584F00000 0x07800
Kernel lsdk_linux.itb 16 MiB 0x01000000 NA NA NA NA 0x08000
Ramdisk rfs 32 MiB 0x02000000 NA NA NA NA 0x10000
The following figures highlight the changes in the flash layout for previous boot flow (with PPA) and flash layout for TF-A boot flow.
Flash layout for previous boot flow (with PPA)
Changed flash layout for TF-A boot flow
ラベル(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1122908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETF-A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BTF-A%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E5%90%91%E3%81%91%E3%81%AELSDK%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%22%3ELSDK%2018.12%E4%BB%A5%E9%99%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%20%3C%2FPRE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A1%A8%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEQorIQ%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AENOR%2FNAND%2FQSPI%E5%9E%8B%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AFSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%20modifiedtitle%3D%22true%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8CNOR%E5%9E%8B%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E8%B5%B7%E5%8B%95%E5%85%83%E3%81%AENOR%E3%83%90%E3%83%B3%E3%82%AF%E3%81%AF%E3%80%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF%E3%80%8D%E3%81%A8%E8%A6%8B%E3%81%AA%E3%81%95%E3%82%8C%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E6%96%B9%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF%E3%81%AF%E3%80%8C%E4%BB%A3%E6%9B%BF%E3%83%90%E3%83%B3%E3%82%AF%E3%80%8D%E3%81%A8%E8%A6%8B%E3%81%AA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81LS1043ARDB%E3%81%8CNOR%E3%83%90%E3%83%B3%E3%82%AF4%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%80%81NOR%E3%83%90%E3%83%B3%E3%82%AF0%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%E4%BB%A3%E6%9B%BF%E3%83%90%E3%83%B3%E3%82%AF%E3%80%8D%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%AF%84%E5%9B%B2%E3%81%A8%E3%81%97%E3%81%A60x64000000%EF%BD%9E0x64F00000%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FPRE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%20width%3A%2080.121%25%3B%22%3E%20%3CTHEAD%3E%20%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2033px%3B%22%3E%20%3CTH%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2033px%3B%22%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%AE%9A%E7%BE%A9%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2010%25%3B%20height%3A%2033px%3B%22%3EMaxSize%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2012%25%3B%20height%3A%2033px%3B%22%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%EF%BC%88QSPI%2FNAND%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%89%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2012%25%3B%20height%3A%2033px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E7%B5%B6%E5%AF%BE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%EF%BC%88LS1043ARDB%E3%80%81LS1021ATWRNOR%E4%B8%8A%E3%81%AE%E3%83%90%E3%83%B3%E3%82%AF0%3C%2FSPAN%3E%EF%BC%89%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2012%25%3B%20height%3A%2033px%3B%22%3E%20%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%3E%E7%B5%B6%E5%AF%BE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3C%2FSPAN%3ENOR%E3%83%90%E3%83%B3%E3%82%AF4%20LS1043ARDB%E3%80%81LS1021ATWR%EF%BC%89%3C%2FP%3E%20%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2012%25%3B%20height%3A%2033px%3B%22%3E%20%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E7%B5%B6%E5%AF%BE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%EF%BC%88LS2088ARDB%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E4%B8%8A%E3%81%AE%3CSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ENOR%E3%83%90%E3%83%B3%E3%82%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2012%25%3B%20height%3A%2033px%3B%22%3E%20%3CP%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%E7%B5%B6%E5%AF%BE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FP%3E%20%3CP%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23efefef%3B%20font-weight%3A%20bold%3B%22%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3C%2FSPAN%3ELS2088ARDB%3CSPAN%3E%E4%B8%8A%E3%81%AE%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3ENOR%E3%83%90%E3%83%B3%E3%82%AF%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%3C%2FTH%3E%20%3CTH%20style%3D%22width%3A%2014%25%3B%20height%3A%2033px%3B%22%3ESD%E9%96%8B%E5%A7%8B%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%3C%2FTH%3E%20%3C%2FTR%3E%20%3C%2FTHEAD%3E%20%3CTBODY%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3ERCW%20%2B%20PBI%20%2B%20BL2%20(bl2.pbl)%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E1%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00000000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60000000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%3E0x64000000%3C%2FTD%3E%20%3CTD%3E0x580000000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%20%3CP%3E0x584000000%3C%2FP%3E%20%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x00008%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EATF%20FIP%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%EF%BC%88fip.bin%EF%BC%89BL31%20%2B%20BL32%20%2B%20BL33%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E4%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00100000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60100000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64100000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580100000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584100000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x00800%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E7%92%B0%E5%A2%83%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E1%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00500000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60500000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64500000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580500000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584500000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x02800%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E2%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00600000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60600000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64600000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580600000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584600000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x03000%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%E3%81%BE%E3%81%9F%E3%81%AFDDR%20PHY%20FW%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E512%20KiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00800000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60800000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64800000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580800000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584800000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04000%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EFuse%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%98%E3%83%83%E3%83%80%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E512%20KiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00880000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60880000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64880000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580880000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584880000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04400%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EDPAA1%20FMAN%20ucode%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E256%20KiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00900000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60900000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64900000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580900000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584900000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04800%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EQE%2FuQE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E256%20KiB%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00940000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60940000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64940000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580940000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584940000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04A00%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88PHY%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E256%20KiB%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00980000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60980000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64980000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580980000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584980000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04C00%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%94%A8%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E256%20KiB%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x009C0000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x609C0000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x649C0000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x5809C0000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x5849C0000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x04E00%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EDPAA2-MC%20%E3%81%BE%E3%81%9F%E3%81%AF%20PFE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E3%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00A00000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60A00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64A00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580A00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584A00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x05000%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EDPAA2%20DPL%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E1%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00D00000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60D00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64D00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580D00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584D00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x06800%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3EDPAA2%20DPC%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E1%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00E00000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60E00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64E00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580E00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584E00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x07000%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20colspan%3D%222%22%20style%3D%22width%3A%2032%25%3B%20height%3A%2024px%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%83%84%E3%83%AA%E3%83%BC%EF%BC%88UEFI%E3%81%A7%E5%BF%85%E8%A6%81%EF%BC%89%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E1%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x00F00000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x60F00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x64F00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x580F00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E%3CSPAN%3E0x584F00000%3C%2FSPAN%3E%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x07800%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20style%3D%22width%3A%2022%25%3B%20height%3A%2024px%3B%22%3EKernel%3C%2FTD%3E%20%3CTD%20rowspan%3D%222%22%20style%3D%22width%3A%2010%25%3B%20height%3A%2048px%3B%22%3Elsdk_linux.itb%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E16%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x01000000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x08000%3C%2FTD%3E%20%3C%2FTR%3E%20%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%20%3CTD%20style%3D%22width%3A%2022%25%3B%20height%3A%2024px%3B%22%3ERamdisk%20rfs%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2010%25%3B%20height%3A%2024px%3B%22%3E32%20MiB%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3E0x02000000%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2012%25%3B%20height%3A%2024px%3B%22%3EN%2FA%3C%2FTD%3E%20%3CTD%20style%3D%22width%3A%2014%25%3B%20height%3A%2024px%3B%22%3E0x10000%3C%2FTD%3E%20%3C%2FTR%3E%20%3C%2FTBODY%3E%20%3C%2FTABLE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E3%81%AF%E3%80%81%EF%BC%88PPA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%EF%BC%89%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8TF-A%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AE%E5%A4%89%E5%8C%96%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3E%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%88PPA%E3%82%92%E4%BD%BF%E7%94%A8%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PPA-flash-layout.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PPA-flash-layout.png%22%20style%3D%22width%3A%20758px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113493iDE11FBC295130113%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PPA-flash-layout.png%22%20alt%3D%22PPA-flash-layout.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPPA-flash-layout.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%3ETF-A%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E5%A4%89%E6%9B%B4%E5%BE%8C%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TFA-flash-layout.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22TFA-flash-layout.png%22%20style%3D%22width%3A%20759px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113494i7C22CC2B9D117A0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22TFA-flash-layout.png%22%20alt%3D%22TFA-flash-layout.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETFA-flash-layout.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EQorIQ%20LS2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:56 AM
更新者:
