lpc1769 programmer
lpc1769 programmer
Content originally posted in LPCWare by karanmehta93 on Wed Jan 02 15:54:29 MST 2013
Does any one have a circuit diagram of lpc1769 programmer that uses UART0?
Does any one know how does the programmer work?
Content originally posted in LPCWare by cfb on Sat Jan 05 15:04:05 MST 2013
You should be able to find all the information you need in the FlashMagic User Manual and the LPC17xx User Manual (UM10360).
In particular, read Chapter 32: LPC17xx Flash memory interface and programming for details of how the bootloader and ISP programming works.
[B][FONT=Arial][SIZE=4][COLOR=#005042][FONT=Arial][SIZE=4][COLOR=#005042][FONT=Arial][SIZE=4][COLOR=#005042]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/B][FONT=Arial][SIZE=4][COLOR=#005042][FONT=Arial][SIZE=4][COLOR=#005042][FONT=Arial][SIZE=4][COLOR=#005042][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
Content originally posted in LPCWare by karanmehta93 on Sat Jan 05 12:51:01 MST 2013
Thanks for that.
I was more interested in programming only lpc 1769 and not through lpc expresso board. I was also interested in it's working.
Please help if you can
Content originally posted in LPCWare by cfb on Fri Jan 04 00:44:33 MST 2013
A few months ago I posted a message on our Astrobe forum with information on how to set this up so that you can program an LPC1769 via UART0 when using Astrobe to develop LPC1769 software:
[COLOR=#5174a3]http://www.astrobe.com/forum/viewtopic.php?f=7&t=200[/COLOR]
You can use a similar approach if you are using the LPCXpresso IDE or other development tool. Just configure your IDE to generate a HEX format file for your executable and then use FlashMagic to upload it to your MCU:
[COLOR=#5174a3]http://www.flashmagictool.com[/COLOR]
