lib file in LPCXpresso
lpcware
Content originally posted in LPCWare by borik2003 on Thu Nov 18 02:29:59 MST 2010
HI,
What are the steps to create and include Lib file into the main project ?
Original Attachment has been moved to: 1100843_screenshot.zip
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Nov 18 02:52:24 MST 2010
To create a library, select
[B][FONT=Courier New][SIZE=1]Quickstart Panel - Project and File Wizards - Create C Static Library project[/SIZE][/FONT][/B]
To use a library from other projects, see http://support.code-red-tech.com/CodeRedWiki/LibraryProjects
CodeRedSupport
