Run from menu LPCXpresso 6
2,685 次查看
lpcware
Content originally posted in LPCWare by Luis Digital on Tue Oct 29 17:46:45 MST 2013
With LPCXpresso 6.x is not possible to launch the application, unless you select: open the console.
openSUSE.
Thank you.
5 回复数
2,677 次查看
lpcware
Content originally posted in LPCWare by elektronist on Wed Oct 30 11:41:45 MST 2013
Same here for Rosa Linux.
For menu entry I use your solution too.
If /usr/local/lpcxpresso_6.0.4_159/lpcxpresso/lpcxpresso clicked in Dolphin, program runs with no problem. (as user)
But this is the good. The bad is with updated webkit1.0-2.0.4 package there is no way to run lpcxpresso. I have to downgrade to webkit1.0-1.10.0.
2,675 次查看
lpcware
Content originally posted in LPCWare by Luis Digital on Wed Oct 30 08:49:02 MST 2013
I'm trying to run LPCXpresso from the menu. The program starts to load, but then stops, no errors.
If I select run in terminal (kmenuedit), then it works.
2,675 次查看
lpcware
Content originally posted in LPCWare by Luis Digital on Wed Oct 30 08:41:42 MST 2013
Quote: vilserg
"open the console" means with root rights?
No.
2,675 次查看
lpcware
Content originally posted in LPCWare by vilserg on Wed Oct 30 08:27:49 MST 2013
2,675 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Oct 29 21:04:12 MST 2013
Sorry, but I have no idea what you are referring to.
Perhaps you explain what you are trying to do and what you think is wrong, and why.
