Reset
Reset
lpcware
Content originally posted in LPCWare by blasiis on Tue Apr 13 07:06:04 MST 2010
I need to debug the first instruction executed.
I use the LPCXpresso and LPC1768.
When I start the debug after reset, the current instruction is already to the first instruction of the main.
But first the main, there'is also the cr_startup_lpc17.c. how can I debug this part of the code ?
lpcware
Content originally posted in LPCWare by blasiis on Wed Apr 14 06:01:06 MST 2010
OK, Thanks !!
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Apr 13 07:21:09 MST 2010
Please read this knowledgebase article for information on how to do this.
http://lpcxpresso.code-red-tech.com/LPCXpresso/node/48
(Login required)
