Renaming a custom lib doesn't update liblinks.xml
Content originally posted in LPCWare by 1234567890 on Mon Apr 06 02:22:06 MST 2015
In liblinks.xml are lines like
${workspace_loc:/delay_lpc11xx_lib
to point to the relevant path/folder. When renaming the lib these path isn't updated with the new name of the lib and must be edited manually to work.
Content originally posted in LPCWare by lpcxpresso-support on Mon Apr 06 09:19:15 MST 2015
This is expected behaviour and is the way that liblinks.xml files have always worked.
LPCXpresso Support
