Renaming a custom lib doesn't update liblinks.xml
692 次查看
lpcware
Content originally posted in LPCWare by 1234567890 on Mon Apr 06 02:22:06 MST 2015
In liblinks.xml are lines like
${workspace_loc:/delay_lpc11xx_lib
to point to the relevant path/folder. When renaming the lib these path isn't updated with the new name of the lib and must be edited manually to work.
683 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Apr 06 09:19:15 MST 2015
This is expected behaviour and is the way that liblinks.xml files have always worked.
LPCXpresso Support
