Printing the manual
Printing the manual
916件の閲覧回数
lpcware
Content originally posted in LPCWare by Luis Digital on Mon Mar 22 08:05:46 MST 2010
I am interested in printing the manual (User manual, LPC13xx or LPC11xx, Rev. 01.01, Jan. 2010), but do not want the watermark (DRAFT). I found a document without the mark, but it has an earlier date (Rev. 01, Nov. 2009).
Where to find an updated document without the watermark or an easy way to remove it?
Thanks.
2 返答(返信)
909件の閲覧回数
lpcware
Content originally posted in LPCWare by Luis Digital on Thu Mar 25 09:12:06 MST 2010
Yes, I see you have updated the User Manual for LPC11xx. Thank you very much.
I did a print anyway, and the watermark is barely visible. The cost was about 15 cc/ml of ink, that is $ 1. :-)
909件の閲覧回数
lpcware
Content originally posted in LPCWare by NXP_Europe on Thu Mar 25 06:42:06 MST 2010
Hi Luis Digital,
The Draft isn't removable from the .pdf-file.
Note that we're continuous improving our datasheets and user manuals, also using all the good inputs you guys put on this forum. So if you print-out the DS or UM, you'll not have the latest version!
