Looking for a free compiler
1,386 次查看
Content originally posted in LPCWare by Senso on Wed Nov 17 16:23:05 MST 2010
Goodnight to everybody, can someone help me about how to get the free arm-gcc compiler compiling code for the LPCXpresso1768 board.
Thanks in advance.
5 回复数
1,327 次查看
Content originally posted in LPCWare by Luis Digital on Thu Nov 18 17:05:39 MST 2010
The [SIZE=4][B]compiler[/B][/SIZE] ([COLOR=#000000]Enter your favorite in this line_____________[/COLOR]) has no limit.
The [SIZE=4][B]debugger[/B][/SIZE] ([COLOR=#000000]Combination of hardware and software[/COLOR]) has the 128k limit.
If the communication protocol of the LPC-Link was free and open there is no such limit. So it is not free nor open. :D
Oh! [COLOR=#000000]You can also purchase a license to remove the limit or use another product.[/COLOR]
1,327 次查看
Content originally posted in LPCWare by Senso on Thu Nov 18 16:43:21 MST 2010
And it keeps doing the upload to the board even if the code exceeds the 128Kb limit?
Thanks for the response.
1,327 次查看
Content originally posted in LPCWare by CodeRedSupport on Thu Nov 18 10:36:48 MST 2010
The *compiler* has no limit.
The *debugger* has the 128k limit.
1,327 次查看
Content originally posted in LPCWare by thinkchip on Thu Nov 18 10:24:33 MST 2010
but, there is no limit 128k to program memory flash??
1,327 次查看
Content originally posted in LPCWare by CodeRedSupport on Thu Nov 18 00:58:00 MST 2010
The LPCXpresso IDE is free and uses gcc. Read the Getting started to see how to use it:
http://ics.nxp.com/support/documents/microcontrollers/pdf/lpcxpresso.getting.started.pdf
