LPCxpresso support for LPC2378 and debug probe
702 次查看
lpcware
Content originally posted in LPCWare by jcornel3 on Mon Oct 13 08:36:08 MST 2014
While the support info says that the LPC23xx series is supported I do not find any debug probe support for the arm7 chip listed when I use either the LPC-link2 probe or the Kiel Ulink2 probes.  How can I download code to this arm chip?  The box shows no listed probes when I try to download and the message: " Redlink Server does not support NXP LPC2378 (arm7tdmi)" gets displayed.
I am running Windows 7 sp1 64bit and the latest version of LPCxpresso.
653 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Oct 13 12:12:23 MST 2014
LPC-Link2 does not support debugging LPC23xx (ARM7) parts…
http://www.lpcware.com/content/faq/lpcxpresso/lpc-link2-support
You will need an LPC-Link [or Red Probe+] - so an LPCXpresso v1 board with the debug probe split off, as described at:
http://www.lpcware.com/LPCXpressoV1Boards
LPCXpresso Support
